Circuit Requirements Questions (Design of a stadium lighting system)
The discussion revolves around the design requirements for a stadium lighting control system, focusing on the integration of various components such as light sensors, LEDs, and circuit blocks. Participants are prompted to explore the functionality and interconnections of these components through a series of questions related to circuit design and operation.
  • Homework-related
  • A controller is needed to monitor ambient light and activate external lighting when necessary, using components like LDRs and LEDs.
  • Participants are asked to provide a block diagram and circuit diagram, outlining the functions of different circuit blocks and their interconnections.
  • There is a discussion about the reliability of using a thermistor to detect the operation of an incandescent bulb.
  • Participants are prompted to suggest alternative methods for determining the operational state of the bulb besides using an LDR.
  • Questions are raised about the necessity of a time delay function in the circuit design to indicate bulb failure.
  • The importance of series resistors for LEDs in the circuit is questioned, with a request for explanations.
  • Suggestions for improving the operation of the circuit are invited.
  • Some participants express that they have completed the project but seek to compare their work with others, while others emphasize the need to show effort before receiving assistance.
There is no consensus on the specific circuit design or the answers to the posed questions. Some participants are focused on providing assistance, while others are more concerned about adherence to forum rules regarding homework submissions.
Participants have not provided detailed responses to the questions posed, leading to a lack of clarity on individual approaches or solutions. The discussion reflects varying levels of engagement with the project requirements.
This discussion may be useful for students or individuals involved in electronics design, particularly those working on projects related to lighting systems and circuit integration.
buyahyeh
[Thread moved from a technical forum, so no Homework Template is shown]
A controller is required to monitor the natural illumination of a sports stadium and, when the ambient light is below a pre-set level, to switch on external lighting. The system is required to be of high integrity, and various monitoring indicators are to be incorporated as specified below. Furthermore, the status of the light (Large white LED) is to be monitored, and if this should fail, when the lighting should in fact be on, a warning signal is to be given in the form of a flashing orange LED.The circuit brief states: 1. A light dependent resistor (LDR) is to be used to determine ambient light levels. 2. A red light emitting diode (LED) should illuminate whenever the ambient light level is below the pre-set value. 3. A green LED should be illuminated if the ambient light is above the predetermined level. Note, the use of two LEDs in this manner serves to indicate that power is applied to the system, as one LED will always be on. 4. An orange LED is to flash on and off repeatedly, in the case that the ambient light level is low, and the white LED is not illuminated, i.e., it has failed. 5. Individual functional blocks of the circuit should be constructed using breadboard, and operation verified, before soldering the relevant components to circuit strip board. One example of such a component block may be the LDR and comparator light detection circuit.
Questions
1. Provide a block diagram of the complete lighting controller, and outline the functions of the different circuit blocks. State how the different blocks interlink. A scanned hand drawn diagram is acceptable.
2. Provide a circuit diagram of the circuit that you actually produced. State the basic principles of the method of operation.
3. Theinitialsectionofthecircuitincorporatesalightdependentresistor(LDR),apotentiometer and an operational amplifier (op-amp) to detect ambient light levels. State the manner in which this part of the circuit functions.
4.A thermistor could have been used to determine when the incandescent bulb was illuminated. State if you consider this to be a reliable system to sense correct operation of the bulb.
5. By what method, other than the incorporation of an LDR, could the operational state of the bulb be determined?
6. The original circuit specified the use of a NAND gate oscillator state the operating principles of this portion of the circuit and which component you used to satisfy this function.
7. The circuit as originally designed may have incorporated a time delay function to ensure correct operation of that part of the circuit intended to indicate that the incandescent light had failed. Why would the time delay be necessary?
8. All of the light emitting diodes (LEDs) in the circuit have a resistor in series. Why are these resistors necessary?
9. Suggest a method of improving operation of circuit
:welcome:
If this is homework, or a school project, our rules say that you show us your work before we can help. So please post your thoughts on those 8 questions.
The post should also be placed in one of our homework forums.
As Anorlunda says, this looks like a homework/school project
What have you done so far to work through this ?
No one here is going to do your project for you
You need to show serious amounts of effort on your part to work through the requirements of the project
Surely your study work throughout this year and previous years has taught you a lot about these various components and how they workcheers
Dave
New user has been reminded to show their work on schoolwork questions
i have done it but i want to see what others would put
So let's see what you did.
That is NOT the way it works on this forum. Read the rules. Show your work.
  • · Replies 25 ·
