Circuit theory -- Conditions to balance a resistive bridge circuit
The discussion focuses on the conditions required to achieve zero current through Ze in a resistive bridge circuit, specifically when Vx equals Vy. Participants emphasize that both pairs of impedances, Za and Zd, as well as Zb and Zc, must be equal simultaneously for balance. The derived formula for Zc is Zc = (Zb * Zd) / Za, with specific values provided (Za = 5k, Zb = 3k, Zd = 12k), resulting in Zc = 7.2k. The conversation highlights the importance of understanding the relationships between the impedances in the circuit.
  • Understanding of resistive bridge circuits
  • Knowledge of impedance and voltage relationships
  • Familiarity with circuit analysis techniques
  • Basic algebra for manipulating equations
  • Study Kirchhoff's laws for circuit analysis
  • Learn about Thevenin's and Norton's theorems
  • Explore advanced topics in AC circuit analysis
  • Practice solving complex impedance problems
Electrical engineering students, circuit designers, and anyone involved in analyzing or designing resistive bridge circuits will benefit from this discussion.
CG139
1. Homework Statement
Establish the condition required to make the current through Ze in Figure 1 zero (i.e. For the voltage Vx to equal Vy).
I'm not sure if I'm on the right line here, hopefully someone can point me in the right direction if it's wrong...
If Zb and Zc were the same value then the voltage drop across them would be equal, likewise Za and Zd would also have to be the same value to have voltage Vx equal to Vy. In this condition there will be no current flowing through Ze.
Is my attempt correct or at least on the right path?
Thanks in advance
Hi CG139. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
You've indicated here a special case of the more general right answer. :)
To add to NO's statement, you have selected not only a special case but a VERY special case ... that is, it is NOT enough that Zb=Zc or that Za=Zd it would be necessary that BOTH of those conditions occur at the same time. This is a very special case indeed.
Think about the relationships between Za to Zb and Zc to Zd
That is, basically your statement
Is very limited. Specifically, "If Zb and Zc were the same value then the voltage drop across them would be equal" is a very limited case because it then REQUIRES that Za=Zd
It is better to allow the poster some opportunity to think about the response, rather than leaping in and doing the thinking for him. In the long run, depriving a poster of the opportunity to review his own work is performing a disservice.
A little restraint can provide a poster the necessary time to process what his attention has been drawn to.
I know it's tempting to scramble to fill in what a previous poster has left unsaid. It was alluded to but left unstated for good reason.
Yeah, you are right. I normally do that and in fact I sometimes chide others for not doing it. Thanks.
Thanks NascentOxygen and Phinds, this subject has had me scratching my head a lot and I'm not sure I've fully understood the replies. Do I just need to expand my statement to include that both conditions need to occur at the same time? When I wrote my original statement I was thinking that, i just didn't make it clear- will try harder.
Dear CG,
Can you write down an expression for Vx using the variables in this figure ?
Hi BvU,
Vx = (Za / (Zb+Za)) *Vin
I struggled to get the format how I wanted it. I've tried to use Latex but don't think I can use it as I'm using a tablet rather than a laptop.
Very well. Now Vy in this picture:
Vy = (Zd / (Zc+Zd)) *Vin
Going back to your original diagram. Given these values, calculate ZC for the balance condition (i.e., no current through Ze)
ZA = 5k,
ZB = 3k
ZD = 12k
ZC = ?
Dear CG,
As O2 isn says more or less, we now go towards vx = vy.
Simply grab together vx = vy, #8 and #10. You see that Vin can be divided out.
That already gives you an adequate answer for the exercise. But it can be made more compact and more elegant by inverting on both sides and subtracting 1.
NascentOxygen,
Zc = (Zb * Zd) / Za
Zc = (3k * 12k) / 5k
Zc = 7.2k
These values would balance the circuit (Vx=Vy).BvU,
Sorry, but I don't fully understand #12. Apologies for my poor knowledge, I'm a long way from my comfort zone with this and the material from my Uni doesn't seem to help (not helped by the fact my maths is also poor).
By 'grab together' do you mean simplify to create one expression?Thanks to you both for your help so far, it is very much appreciated!
No need to apologize. Yes, grab together is an undiplomatic way to say: if x=u and y=v and x=y then u = v. Mathematicians might say "use symmetry and transitivity", physicists just grab :)
Vx = (Za / (Zb+Za)) *Vin (your post),
Vy = (Zd / (Zc+Zd)) *Vin (your post), and from the exercise wording:
Vx = Vy (we're not interested in either of these two, they just have to be equal)
"Grab together" is then luring you to write (Za / (Zb+Za)) *Vin = (Zd / (Zc+Zd)) *Vin
Vin in itself isn't all that interesting either, bringing us to (Za / (Zb+Za)) = (Zd / (Zc+Zd))
This time you have a general answer, not just something for a special case.
(a few pathological cases have to be excluded, though: Vin = 0, Zb+Za = 0, Zc+Zd=0; no big deal)
That (Za / (Zb+Za)) = (Zd / (Zc+Zd)) already is an adequate answer for the exercise. But it can be made more compact and more elegant by inverting on both sides and subtracting 1. That way you get an expression the exercise is really asking for.
Can you express the result in words? I'm still not sure that you recognize the general solution ...:nb)
