Circuit with 2 batteries when one has a reversed polarity
Connecting a 12-volt battery in series with a 6-volt battery of reversed polarity results in a net voltage of 6 volts, as the 6-volt battery opposes the 12-volt battery. This configuration can cause the 12-volt battery to force current through the 6-volt battery, potentially damaging it due to overheating and internal resistance. The lightbulb will not shine brightly, as the opposing voltage reduces the effective voltage supplied. Practically, this setup is dangerous and can lead to battery failure or even fire hazards. It is advised to avoid such configurations to prevent damage and safety risks.
johann1301
What happens if you take let's say a 12 volt battery and connect it to a lightbulb(not LED). Well... the lightbulb lights up obviously! But then connect a 6 voltage battery also(in series), but with reversed polarity (against the current that is). What happens then?
Will there be a shortage of some sort, or will the lightbulb give half the effect/shine half as bright? (or something else maybe??)
If the battery is connected with the same polarity, the total voltage would be 18V(12V+6V)(so I've learned). Will it in this case be 12V-6V=6V?
Thanks;) (excuse my english)
Science news on Phys.org
You have the right answer...6volts...
In practice the 12 volt battery will force current thru the smaller battery and likely ruin it in short order. Depending on the internal resistances of the batteries, heat will be generated
and damage results. NEVER do this in practice because I'm pretty sure with powerful enough batteries, like those in a typical car, fire or at least melting will occur.
You can read a little bit about ideal voltages sources here:
http://en.wikipedia.org/wiki/Ideal_voltage_source#Ideal_voltage_sources
Thanks;)
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
