Circular Motion Question (Possibly Easy?)
The discussion revolves around a problem related to circular motion, specifically focusing on determining the banking angle of a highway curve designed for vehicles moving at a certain speed. The radius of the curve is given, and the speed of the traffic is provided in different units.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • The original poster attempts to use a free body diagram to analyze forces but expresses uncertainty about how to proceed without the mass of the vehicle. Some participants suggest focusing on the components of forces involved in circular motion and indicate that mass may not be necessary for the calculations.
Participants are exploring different aspects of the problem, including the relevance of the equations provided and the interpretation of the free body diagram. There is a focus on understanding the forces acting on the vehicle and how they relate to the banking angle, with some guidance offered regarding the cancellation of mass in the equations.
There is a mention of the absence of friction in the problem, which is a critical assumption affecting the analysis of forces. The original poster is also navigating between different units of speed, which may contribute to the confusion in their calculations.
BlakeGriffin
A highway curve of radius 420m is designed for traffic moving at a speed of 73.0 km/hr .
What is the correct banking angle of the road?
V=(2(pi)(r)/T)
a=(v^2)/r
I feel like this is an easy question but for some reason I can't get it.
r=420m
v=73 mi/hr which is 20.3 m/s
I was going to use a free body diagram to find the normal force then use the cos and sin stuff to find the angle but since the mass is not given I don't know what to do.
I don't know where to go exactly? Can anyone just tell me what I'm missing here?
A body that moves in a circle needs a net force to move in this circle. If the circle has a radius R and the body moves with a speed v then the force needed to keep the body in the circle is given by mv^2/r, using Newtons first law and sentriple aceleration. This is one way to write this force
F=mv^2/r
So, what force is it that keeps it in the circle? Well there is no friction, so we need an angle and a component from the normal force. Do you know how to find this component? Find the component in therms og m, g and the angle and sustitute for F. Notice that the m-s cancel, so you don't need them. Then solve for the angle and youre done.
Basically, for a flat road, friction is what provides the centripetal force that keeps the car moving in a circle. If you bank the curve, then there is also a component of the weight that is parallel to the incline that helps you out as well. Draw the free body diagram and set up the equations, and you should see that mass doesn't matter (it cancels from both sides of the equation).
Btw, your first equation is not relevant
So is this what the free body diagram looks like then?
http://img851.imageshack.us/img851/3382/232.jpg
Dash marked lines are the components of normal force.
I was having trouble interpreting that FBD, but if the vertical force is weight and the oblique one is the normal force, then that looks right. So, is there no friction in this problem? If not, then the FBD is complete.
  • · Replies 17 ·
