Classical hydrogen "molecule" - can it be stable?
The discussion centers on the stability of a classical hydrogen "molecule," which consists of two electrons and two protons arranged in specific geometric configurations. The participants explore the possibility of achieving a stable or metastable state by utilizing Coulomb energy calculations for arrangements such as a square or tetrahedron. They conclude that while negative Coulomb energy suggests potential stability, the configuration may ultimately lead to collapse due to the inherent forces acting on the particles. The concept of anti-coordinated electron movement is proposed as a means to mitigate radiation effects.
  • Coulomb's Law and electrostatic interactions
  • Basic principles of classical mechanics
  • Understanding of molecular geometry and configurations
  • Concept of metastability in physical systems
  • Research the implications of Coulomb energy in multi-particle systems
  • Explore the concept of metastability in classical physics
  • Study the dynamics of charged particles in electrostatic fields
  • Investigate the role of geometric configurations in molecular stability
This discussion is beneficial for physicists, chemists, and students interested in classical mechanics, electrostatics, and molecular stability. It provides insights into the behavior of charged particles in various configurations and their implications for stability.
Swamp Thing
Insights Author
Is it possible to have a configuration of two classical positive charges and two classical negative charges that will remain fairly stable (or at least metastable), if started off in some well-chosen initial condition?
For example, we might want to eliminate radiation by having the electrons move in an anti-coordinated figure-of-eight pattern so that their radiation fields cancel out at any distant point. Would that help to achieve a configuration that will not explode or implode right away?
Hi.
Hydrogen molecule consists of two electrons and two protons. Say we put them on the corners of square whose length of the side is a. Coulomb energy (-1-1-1-1+1/√ 2+ 1/√ 2)e^2/a is negative so we may have a chance to pack many of them like sodium chloride crystals.
In 3D case of regular tetrahedron, Coulomb energy (-1-1-1-1+1+1)e^2/a is negative also.
I was somehow assuming that you need the electrons to be orbiting in order to get a time-averaged zero force.
It's pretty interesting that a static system could be stable.
The Coulomb energy may be negative, but if you make the side of the square a/2 the energy will be twice as negative, a/4 four times, and so on - they will collapse onto each other, just like a static proton and electron at distance a.
Hi.
Yea, as hydrogen atom made of positive charge proton and negative charge electron can not exist with particles apart in classical physics.
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 34 ·
11K
  • · Replies 62 ·
11K
  • · Replies 19 ·
