Classical magnetic energy of two electrons
The discussion centers on deriving the interaction potential for two electrons as presented in G. Breit’s paper, specifically the equation \frac{e^2}{r} \left [1 - \frac{v_1 v_2}{c^2} \right ]. The user expresses confusion over a derived force equation that suggests an additional term in the interaction potential, which seems to be overlooked in the original paper. There is speculation that the simplification may assume parallel velocities for the electrons, raising questions about the validity of this assumption in classical physics. The user is motivated by a desire to understand the origins of the Breit interaction, which is significant in atomic physics. The conversation touches on the historical context and relevance of the paper in the broader study of electromagnetic interactions.
Syrius
Cheers everybody,
I've got a question about an equation in the famous paper "The Effect Of Retardation On The Interaction Of Two Electrons" by G. Breit. There on the first page, it is said, that a first guess for a two electron relativistic wave equation is made by constructing the interaction potential analogously to the classical one \frac{e^2}{r} \left [1 - \frac{v_1 v_2}{c^2} \right ].
If I want to derive this equation by myself I use the formulas
1.) \mathbf{F} = e (\mathbf{v}_1 \times \mathbf{B}) and
2.) \mathbf{B} = \frac{e}{c^2} \frac{\mathbf{v}_2 \times \mathbf{r}}{r^3},
where the first formula describes the Lorentz force that is experienced by the first electron due the B-field that is created by the second electron (Eq. 2). If I plug in Eq. 2 in Eq. 1 and use a vector identity for the cross product I get \mathbf{F} = \frac{e^2}{c^2 r^3} ((\mathbf{v}_1 \mathbf{r})\mathbf{v}_2-(\mathbf{v}_1 \mathbf{v}_2) \mathbf{r}), which as a conclusion asks for a second term in the interaction potential above. It seems that this term has been neglected or that the velocities of the electrons are assumed to be parallel, neither of which I understand why. Why should the electrons move with parallel velocity in a classical treatment. Do you have any suggestions?
Greetings, Syrius
Gregory must have been thinking of simple geometry to simplify the algebra.
Are you interested in history of physics to be studying that paper?
The relativistic force between two moving charges is in (advanced) EM textbooks.
Hello Achuz,
I am studying this paper, because I'd like to know the origin of the Breit interaction, since it appears frequently in atomic physics calculations.
Greetings,
Syrius
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
