Classical mechanics-acc. of a rod using inertia
The discussion revolves around calculating the initial acceleration of a rod's free end when one person lets go. The moment of inertia was initially calculated incorrectly about the center of mass, leading to confusion in deriving the acceleration. After realizing the pivot point is at one end of the rod, the correct approach involves using torque to find the acceleration, which is determined to be 3g/2. Additionally, the second part of the problem addresses how the load supported by the remaining person changes from mg/2 to mg/4, requiring a balance of forces. The participant is struggling to correctly apply the forces after one end is released, indicating a need for further clarification on the dynamics involved.
indie452
1. Homework Statement
two people are holding the ends of a rod length l and mass M, show that if one person let's go the initial acceleration of the free end is 3g/2
3. The Attempt at a Solution
i worked out the moment of inertia about centre mass (cm) and got = Ml2/12
because L=Iw
dL/dt = I*dw/dt
torque (T) = I*ang.acc. (a)
so
a = T/I = mglsin[90] / Ml2/12
= 12g/l
this is wrong so i used l=l/2 as this is the distance to the cm.
so a = 24g/l also wrong
what am i doing wrong?
Are you sure? As you state, this is the moment of inertia about the center of the rod. But if two people are holding the ends and one let's go, it is not rotating about the center, is it?
yeah i realized that now and took the mom.of inertia at the pivot and with torqu found the answer.
the next part of the question however is show how the load supported by the one person falls from mg/2 to mg/4.
i have thought about balancing out the downward forces and the upward forces
F1=mg/2 ...F2=mg/2
|__________________|
....V
.....F=mg
but for the next part after one person has let go i tried saying that F2 will become a downward force = 3mg/2 but this doesn't seem right
