Closed disk of radius limit math problem
The discussion revolves around finding the limit of the integral of a function over a closed disk as the radius approaches zero. The integral can be simplified using the mean value equality, leading to the expression lim r->0 f(x,y) where (x,y) is a point inside the disk centered at (a,b). Participants emphasize the importance of proving the continuity of the function at the center point as r approaches zero. There is a clarification that the coordinates (a,b) do not necessarily equal (0,0) unless specified. The conversation highlights the need for a deeper understanding of sequences in relation to the limit.
ironman2
If Dr is a closed disk of radius r centered at (a,b) find lim r->0 (1/pir2) \int\intfdA over Dr.
From mean value equality, \int\int fdA = f(x,y)A(D) where A(D) is the area of the region which here is pir2. So the lhs becomes lim r->0 f(x,y). Where do I go from here?
welcome to pf!
hi ironman2! welcome to pf! :smile:
ironman2 said:
… So the lhs becomes lim r->0 f(x,y). Where do I go from here?
hint: where is (x,y) ? :wink:
Inside the disk? I thought of using a, b as x,y since a,b were inside the disk and somehow relating a, b to r... but can't seem to do it.
ironman2 said:
Inside the disk?
yup! :smile:
(x,y) is inside the disc Dr round (a,b) …
(btw, it would be more mathematical to call it (xr,yr) :wink:)
so limr->0 f(xr,yr) = … ? :smile:
Since f is continuous, would lim r->0 f(xr,yr) = (a,b)? I'm thinking a,b = 0,0 since its the center...
yes, but you need to prove that, not just say it
hint: sequence :wink:
i've no idea what this means … (a,b) is just (a,b) :confused:
Sequence like Taylor-series? I don't quite understand...
Nvm the 0,0 logic, I was assuming it's a disk centered on the origin, which obviously it's not.
(x1 , y1) , (x2,y2) , (x3,y3) , … (xn,yn) … :wink:
Got it, thanks!
  • · Replies 19 ·
