Proving Closed Rectangle A is a Closed Set
  • Thread starter Thread starter jgens
    Closed Sets
jgens
Prove that a closed rectangle A \subset \mathbb{R}^n is a closed set.
N/A
Let A = [a_1,b_1] \times \dots \times [a_n,b_n] \subset \mathbb{R}^n, then A is closed if and only if its complement, \mathbb{R}^n - A, is open. Now, let x = (x_1, \dots, x_n) \in \mathbb{R}^n - A and choose \varepsilon_i = \inf_{c_i \in [a_i,b_i]}\frac{|x_i - c_i|}{2} > 0. Clearly we have that (x_i - \varepsilon_i,x_i + \varepsilon_i) \cap [a_i,b_i] = \emptyset; thus, we can define an open rectangle B = (x_1 - \varepsilon_1, x_1 + \varepsilon_1) \times \dots \times (x_n - \varepsilon_n, x_n + \varepsilon_n) \subset \mathbb{R}^n - A with the property that for any x \in \mathbb{R}^n - A, x \in B \subset \mathbb{R}^n - A, completing the proof.
My questions:
1) Is this "proof" correct?
2) If so, is there an easier way to do this?
Thanks
No. \varepsilon_i may be zero for some i. Consider the unit square [0,1] x [0,1] in \mathbb{R}^2. The point (1/2, 2) is not in the unit square, but your \varepsilon_1=0.
An easier proof: recall that a set is closed if and only if for a sequence x^{(k)} in the set that converges, the limit is in the set. Now let x^{(k)} be a sequence in A that converges to the point x. For i = 1, 2,..., n we have x_i^{(k)} \to x_i in R. Now, [a_i,b_i] is closed in R (this is very easy to prove), so x_i \in [a_i,b_i] which impies that x \in A.
Ah! That's a really good point. :grumbles quitely:
I haven't learned that formulation of a closed set so I can't really follow your proof (sorry!). So, suppose I revised my proof as follows: Let x = (x_1, \dots, x_n) \in \mathbb{R}^n - A, then for some x_i we have that x_i \notin [a_i,b_i]. I can then choose \varepsilon = \inf_{c_i \in [a_i,b_i]}\frac{|x_i - c_i|}{2} > 0 and since (x_i - \varepsilon, x_i + \varepsilon) \cap [a_i,b_i] = \emptyset I can define the open rectangle B = (x_1 - \varepsilon, x_1 + \varepsilon) \times \dots \times (x_n - \varepsilon, x_n + \varepsilon) \subset \mathbb{R}^n - A. Hence, for any x \in \martbb{R}^n - A there exists an open rectangle B such that x \in B \subset \mathbb{R}^n - A, completing the proof.
Does this work any better? I just started learning about open and closed sets today so I appreciate all the help that I can get. Thanks again!
This almost works like a charm. But the fact that \varepsilon > 0 requires you to prove that [a_i,b_i] is closed in R. There's an easier way to pick \varepsilon = \frac{ 1 }{ 2 } \min \{ |x_i-a_i|, |x_i-b_i| \}.
