Can an Equilateral Triangle be Formed with Rational Vertices on the X-Axis?
  • MHB
  • Thread starter kaliprasad
  • Tags
    Geometry
In summary, the conversation discusses the concept of rational points in a plane and how it applies to an equilateral triangle. It is shown that if all vertices of a triangle are rational, the triangle cannot be equilateral. This is demonstrated by fixing two points on the x-axis and showing that the third point, which must be rational for an equilateral triangle, cannot be rational.
kaliprasad
MHB
1,335
in a plane point is said to be rational if both x and y co-ordinates are rational. Show that if in a $\triangle$ ABC all the vericles A , B, c are rational then $\triangle$ cannot be equilateral
Mathematics news on Phys.org
[sp]Suppose that $ABC$ is an equilateral triangle whose vertices are all rational. By translating the axes through rational distances, we may assume that $C$ is at the origin. Let $A$ be the point $(x,y)$ and $B$ be the point $(u,v)$, where $x,y,u,v$ are all rational. The linear transformation of rotation through $\pi/3$ takes $A$ to $B$. But this transformation is given by the matrix $\begin{bmatrix} \cos(\pi/3) & -\sin(\pi/3) \\ \sin(\pi/3) & \cos(\pi/3) \end{bmatrix} = \begin{bmatrix} \frac12 & -\frac{\sqrt3}2 \\ \frac{\sqrt3}2 & \frac12 \end{bmatrix}.$ It follows that $\begin{bmatrix} u \\ v \end{bmatrix} = \begin{bmatrix} \frac12 & -\frac{\sqrt3}2 \\ \frac{\sqrt3}2 & \frac12 \end{bmatrix} \begin{bmatrix} x \\ y \end{bmatrix} = \begin{bmatrix} \frac12 x -\frac{\sqrt3}2y \\ \frac{\sqrt3}2 x + \frac12y \end{bmatrix},$ so that $u = \frac12 x -\frac{\sqrt3}2y$. But then $\sqrt3 = \frac{x-2u}y$ – a contradiction since the right side is rational and the left side is not. Therefore no such triangle can exist.[/sp]
great answer by Opalg. This gives me another insight of the solution
my solution
Without loss of generality we can chose the co-ordinates ( we can make this by proper shift of co-ordinates) as A= (0,0), B= (x,y), C=(a,b) with x y
a and b being rationalNow slope of AB = $\frac{y}{x}$ is rational
Slope of AC = $\frac{b}{a}$ is rationalSo $\tan\angle (BAC) = \frac{\frac{y}{x} –\frac{b}{a}} {1 + \frac{by}{ax}}$ which is rational as both numerator and denominator are rational
As $\tan \, 60^0 = \sqrt(3)$ is irrational so $\angle (BAC)$ cannot be $60^0$ as tan of the angle is rational.
so the triangle cannot be equilateral
Hence proved
if $\triangle ABC$ is equilateral with side length a
let x and y coordinates of points being :$A(0,0),B(a,0),C(\frac{a}{2},b)$
(here $a,b$ are all rational)
the area of $\triangle ABC=\dfrac {\sqrt 3a^2}{4}=\dfrac {ab}{2}$
$\therefore b=\dfrac {\sqrt 3a}{2}$ is not rational
and we conclude that $\triangle ABC$ cannot be equilateral
B(a,0) does not cover all cases of B for example B=(1,1) by rotation cannot be a rational point in x-axis
we fix point A and B on the x axis,and point C(a/2 ,b)
(here a,b rational) and show that b cannot be rational
if the triangle is equilateral
so we don't even have to rotate
1. What is co-ordinate geometry?
Co-ordinate geometry is a branch of mathematics that deals with the study of geometric shapes using numerical values called coordinates. These coordinates are used to locate points, lines, and shapes on a graph or coordinate plane.
2. How do you graph a line using co-ordinates?
To graph a line using co-ordinates, you need to plot two or more points on a coordinate plane and then draw a line connecting those points. The x-coordinate represents the horizontal position on the graph, and the y-coordinate represents the vertical position on the graph.
3. What is the formula for calculating the distance between two points on a coordinate plane?
The formula for calculating the distance between two points (x1, y1) and (x2, y2) on a coordinate plane is d = √[(x2 - x1)^2 + (y2 - y1)^2]. This is known as the distance formula in co-ordinate geometry.
4. How do you find the slope of a line using co-ordinates?
The slope of a line can be calculated using the formula m = (y2 - y1)/(x2 - x1), where (x1, y1) and (x2, y2) are two points on the line. This formula is also known as the rise over run formula.
5. What is the equation of a line in slope-intercept form?
The equation of a line in slope-intercept form is y = mx + b, where m is the slope of the line and b is the y-intercept (the point where the line crosses the y-axis). This form is useful for quickly graphing a line and finding its slope and y-intercept.
  • General Math
  • General Math
  • General Math
  • General Math
