Coefficient of thermometric conductivity
The discussion centers on the differing definitions of the coefficient of thermometric conductivity in Landau's and Chandrasekhar's books. Landau defines it using thermal conductivity, density, and specific heat at constant pressure, while Chandrasekhar uses constant volume. Participants express that both definitions are valid, highlighting that they represent different measurement approaches. The conversation seeks further clarification and opinions on these definitions. Understanding these distinctions is crucial for accurate application in thermodynamic contexts.
Sagar_C
Landau's book defines it as thermal conductivity/density/specific heat at constant pressure while Chandrasekhar's book defines it as thermal conductivity/density/specific heat at constant volume. I am confused. Any comments?
Likes Ildebrando
Science news on Phys.org
I think both the books are correct. These are just the different "ways" to measure thermometric conductivity.
Any other views ?
Likes Ildebrando
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
