Coefficients for an exponential Fourier Series
The discussion focuses on finding the Fourier series for the function f(θ) = e^(-α|θ|) over the interval -π < θ < π, with the series expressed in the form f(θ) = Σ c_n e^(inθ). The user attempts to derive the coefficients using cosine terms to simplify the calculations, but ends up with a complicated final expression. Feedback from other participants suggests simplifying terms involving cosine and sine functions, which leads to a cleaner result for the coefficients. Ultimately, the user successfully refines their expression for k_n, confirming the correctness of their method.
ElPimiento
I'm kinda just hoping someone can look over my work and tell me if I'm solving the problem correctly. Since my final answer is very messy, I don't trust it.
1. Homework Statement
We're asked to find the Fourier series for the following function:
f(\theta)=e^{−\alpha \lvert \theta \rvert}}, \ \ \ \text{for} −\pi<\theta<\pi,
where ##f(\theta + \pi) = f(\theta)##. Except our Fourier series has the form:
f(\theta) = \sum_{-\infty}^{\infty} c_n e^{in\theta}
Variation on Euler:
\cos{\theta} = \frac{1}{2}(e^{i\theta} + e^{-i\theta})
Vector projection:
proj_\vec{v}(\vec{u}) = \frac{\langle\vec{v}, \vec{u}\rangle}{\langle\vec{v}, \vec{v}\rangle}
So, supposing ##n## is an Integer, I First realized that every positive ##n## has a negative partner, hence our special Fourier series formula can be rewritten as
\begin{align*}
& = c_0 + \sum_{-\infty}^{-1} (c_{n^{(-)}} e^{in\theta}) + \sum_{1}^{\infty} (c_{n^{(+)}} e^{in\theta}) \\
& = c_0 + \sum_{-\infty}^{\infty }k_n (e^{in\theta} + e^{-in\theta}) \\
& = \sum_{-\infty}^{\infty} k_n \cos(n\theta) \\
\end{align*}
Where I have used the variation on Euler's Equation (above) and set ##k_n = (c_{n^{(-)}} + c_{n^{(+)}})/2##.
Then using the inner product:
\langle f(x), g(x) \rangle = \int_{-\pi}^{\pi} dx f(x) g(x)
I found that the coefficients should be:
\begin{align*}
k_n & = \frac{\langle e^{-\alpha \lvert \theta \rvert}, \cos(n \theta) \rangle}{\langle \cos(n \theta), cos(n \theta)\rangle} \\
& = \frac{\int_{-\pi}^{\pi} e^{-\alpha \lvert \theta \rvert} cos(n \theta)} {\int_{-\pi}^{\pi} cos^2(n \theta)} \\
& = \frac{\int_{0}^{\pi} e^{-\alpha \theta} cos(n \theta)} {\int_{0}^{\pi} cos^2(n \theta)} \ \ \ \ \ (\because \text{all the functions are even}) \\
& = - \frac{4 n (\frac{\alpha \cos(\pi n) - n \sin(\pi n)}{(\alpha^2 + n^2)e^{(\pi \alpha)}} - \frac{\alpha}{\alpha^2 + n^2} )} {2 \pi n + \sin(2 \pi n)} \\
\end{align*}
Which is a mess.
I used cosines hoping it would simplify the problem (since they're even and the resulting series starts at 0 instead of ##-\infty##), but it doesn't look like it did much good. So is the method at least right?
Variation on Euler:
Vector projection:
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
Which is a mess.
Why don't you simplify ##\cos(\pi n), \sin(\pi n)## and ##\sin (2 \pi n)##? Remember that ##n## is an integer.
When you do that you get a result that agrees with that obtained using Maple.
Likes ElPimiento
Oh duh, I should've realized that >~<.
Thanks though! That cleaned it up nicely:
k_n = -\frac{2 \alpha (e^{\pi \alpha} - 1)}{\pi (\alpha^2 + n^2)}
Woops! got a little too excited with the cancelation:
\begin{align*}
k_n
& = -\frac{2 \, {\left(\frac{\left(-1\right)^{n} \alpha}{\alpha^{2} e^{\left(\pi \alpha\right)} + n^{2} e^{\left(\pi \alpha\right)}} - \frac{\alpha}{\alpha^{2} + n^{2}}\right)}}{\pi} \\
& = - \frac{2 \alpha ((-1)^n e^{- \pi \alpha} - 1)}{\pi (\alpha^2 + n^2)} \\
\end{align*}
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
