Can Single Photon Beams Exhibit Coherence?
  • Thread starter Thread starter Joseph14
    Coherence Photons
Joseph14
For any light beam it is normal to characterize the coherence length and time. This is done by measuring the ability light to interfere with itself.
Does it make sense to talk about the coherence of a single photon beam, such as the one used in the double slit experiment? Can a single photon beam be incoherent? I imagine this could be tested using a mach-zehnder interferometer.
A single photon could have a coherence relationship to a varying background field. As an analogy you might look at G. P. Thomson's electron beam experiments where single electrons were fired into a very thin gold foil. The arrangement of the atoms in the foil lattice produced a varying field that interfered with the electron. The result was the creation of visible rings (EM fluctuations) spreading out from the impact point.
A single photon state will show ideal first-order coherence in both temporal and spatial domains. In fact, this holds true for any arbitrary pure-state excitation of a single mode and any statistical-mixture state, in which a single mode of the radiation field is excited.
This is discussed for example in chapter 9 of Loudon's "The quantum theory of light" and to some lesser degree in the book about "Mesoscopic quantum optics" by Yoshi Yamamoto and Atac Imamoglu.
It is also discussed in depth in "U. Titulaer and R. Glauber, Density operators for Coherent Fields", Phys Rev, Vol 145, (1966), pp. 1041, but that paper is not an easy read.
However, all single photon states will of course only show first-order, but no second or higher-order coherence. In addition one should also add that real single photon sources are not necessarily creating real Fock states in the sense theory proclaims. Most will produce single photons over a narrow range of energies varying from one photon to the next.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
