Coil, 110 GA, r = 70m. How much tension force is generated?
The discussion centers on generating a magnetic field of 10 T using a coil with a radius of 70 m and a cable radius of 0.2 m, requiring a current of 110 GA. The mechanical stress and tension forces in the loop are debated, with calculations suggesting a force per meter of approximately 2.42×10^15 N, but uncertainty remains regarding the correct adjustment for a loop configuration. Concerns are raised about the practicality of the coil's design, particularly regarding the support structure needed to handle the immense tension and the implications for an antimatter drive system. The proposed application is deemed unviable due to excessive energy requirements and gamma radiation challenges. Overall, the feasibility of constructing such a coil and its intended use in propulsion is questioned.
nehorlavazapal
I need to generate a field of B = 10 T at the center of a magnetic loop (coil). The coil should have r = 70 m. The coil material itself should be a cable of r = 0.2 m. The question, how much mechanical stress is applied throughout the loop? I'm trying to figure out, if such a material (coil) could be made.
Not needed, as the magnetic field equations are widely known among the visitors of the forum. On the other hand, I don't know the relevant equations related to the loop stress (tension forces)
The current flowing through the loop must be 110 GA.
Force per meter F/L between wires separated by 1 meter from F/L = mu_0I^2/(2pid):
= 2.42×10^15 N (Newtons). But I have no idea what to do in the case of a loop (is it lower by factor of 70^2 ? or 140^2?). Is it 1,23*10^11 N or 5*10^11 N? Please help.
If you don't care about small prefactors (like 2, or 1/2), I think assuming a wire at 70m distance will give the right order of magnitude. Note that you have to convert "force per meter" to "tension in the cable" afterwards (the second value will be much larger). A proper analysis would involve integrals over the loop.
Anyway, a support structure can handle this.
I don't think the application for this coil is properly designed.
I can't afford a support structure, it's antimatter drive designed to intercept only a fraction of the hard gammas produced in anihilation. It is not a viable option.
Some new physics is needed to take care of the gammas, the antimatter drive as currently pressented is dead. It needs to produce terrawatts of energy just to produce veery slow accelerations and those TWs of gammas just mlet away and erode the engine during the boost years. If you increase the mass you also push the accel. time to centuries. The loop would allow for 1/4 c in 50 years. However, it breaks.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
