Coil Gun: How It Works & Physics Behind It
  • Thread starter Thread starter Poseidonho
    Coil Gun Work
The discussion focuses on the physics of coil guns, emphasizing that the magnetic field is generated by electric current rather than voltage. Ampere's law is referenced to explain the relationship between current and magnetic fields, with solenoids mentioned as a method to enhance magnetic field strength. The conversation also touches on the conversion of magnetic force to mechanical force when a metal projectile is propelled. It is clarified that the calculation of mechanical force can be derived from the magnetic field, although specific equations are not provided. Overall, understanding the interplay between current, magnetic fields, and mechanical force is crucial for the operation of coil guns.
Poseidonho
What is the physics behind coil gun.
For the magnetic field part, that is convert a electric voltage to the magnetic field. How the magnetic field related to the voltage?
Is there any equation for the conversion the voltage to the magnetic field, maxwell or others?
After that, the magnetic field will push to metal bullet, in this case is it the force is convert from magnetic force to the mechanical force? How to calculate the mechanical force from the magnetic field?
Thanks alot
Every current has an associated magnetic field - see Ampere's law.
When you arrange the current carrying wire appropriately you can increase the magnetic field strength - see solenoids.
When the current is pulsed correctly a metal object can be moved ... do it right and you have a magnetic coil gun: http://en.wikipedia.org/wiki/Coilgun
For other techniques see magnetic rail guns: http://en.wikipedia.org/wiki/Railgun
Likes 1 person
It's not the voltage that determines the magnetic field, it's the current. The voltage and resistance set the current flow.
For the rail gun, the magnetic field on rail do not play any role, Right?
Thanks,
by the way do we can equal the magnetic force to mechanical force?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
