Collapse and unitary evolution
In summary, Susskind's book "The Black Hole War" discusses the concept of unitarity in quantum mechanics and how it relates to the issue of information loss in black holes. He argues that information cannot be lost in quantum mechanics because of unitarity, but this raises questions about the collapse interpretation of quantum mechanics. Susskind favors the many-worlds interpretation and believes that collapse never occurs. However, the issue of information loss in black holes remains even in no collapse interpretations like the many-worlds interpretation. Susskind also discusses the AdS/CFT correspondence and its role in solving the paradox of information in black holes. There is some bias in his conclusion, as the AdS/CFT correspondence is still unproven and may
  • #141
martinbn said:
No, I'll ask if there is such a result about the approximation, or is it just expected. What about stubility?
It's expected by my physical intuition, but maybe I should add that I expect it for ##r>2M(t)##. I'm sure that someone made explicit calculations and haven't obtained anything very surprising, because otherwise I would already heard about that. After all, the mass of the Sun is not constant, yet the Schwarzschild metric describes the motion of planets around Sun very well.
  • #142
Demystifier said:
It's the usual radial coordinate in the Schwarzshild metric.
Or, to make clear that this ##r## labels a geometric invariant, it is the "areal radius" of the 2-sphere on which a given event lies, i.e., if the 2-sphere's area is ##A##, then ##A = 4 \pi r^2##, so ##r = \sqrt{A / 4 \pi}##.
  • #143
Demystifier said:
It's about uncharged nonrotating black hole, with a possibly non-constant mass. If the mass changes sufficiently slowly, then the metric can be approximated by Schwarztschild metric with ##M\rightarrow M(t)##.
The Vaidya metric is an exact solution describing a non-rotating, uncharged black hole either emitting or absorbing null dust (basically incoherent EM radiation emitted or absorbed isotropically, equally in all directions). See here:
https://en.wikipedia.org/wiki/Vaidya_metric
Note that the usual way of writing this metric is in the equivalent of Eddington-Finkelstein coordinates, where there is a null coordinate ##u## or ##v## (depending on whether you are looking at the outgoing--emitting radiation--or ingoing--absorbing radiation--case) instead of the Schwarzschild ##t##. For this case, ##M## is a function of ##u## or ##v## only, as shown in the article, and this is true regardless of the rate of change of ##M## with respect to ##u## or ##v##.
I believe what @Demystifier is referring to is an approximation in which (for the ingoing case) ##dM / dv## is small enough that you can transform into standard Schwarzschild coordinates and still have ##M## be a function of only ##t## (instead of both ##t## and ##r##, as it would be in the general case with unrestricted rate of change) for the duration of the process he is analyzing.
Likes Demystifier
  • #144
The usual treatment of the Solar System is basically the order by order PPN expansion of the Schwarzschild metric for the case of small ##M / r##, yes. But this works well because the mass loss (from radiation, solar wind, etc.) is so small compared to ##M## that its effects are negligible. It's not because the solution explicitly uses an ##M## that is changing with time (at least, that's my understanding).
  • #145
But the Sun is very far from a black hole. I think it requires more justification than intuition to extrapolate. It would be interesting to see a theorem.
Which two sphere?
PeterDonis said:
The Vaidya metric is an exact solution describing a non-rotating...
My exclamation wasn't about which solution describes the scenario but about the fact that it is one solution that he had in mind. The statement seems to be about black holes in general, then it turns out that when physicists say "black hole" they mean the Schwartzschild solution or Vaiday, or something else but just one solution. Demystifier said that it should be a good enough approximation, which is probably true, but it would be interesting to see a precise statement.
  • #146
martinbn said:
Which two sphere?
Whichever 2-sphere the particular event you are interested in (the one labeled with a given value of ##r##) lies on. The entire spacetime is spherically symmetric, which means every event in the spacetime lies on some 2-sphere with a definite area.
  • #147
Ah, ok, so there is an assumption that the space-time is spherecally symmetric.
Likes Demystifier
  • #149
Fra said:
new interactions does emerge as complexity increases, that was physically impossible at lower complexity.
Fra said:
But this is not a viable strategy for one human interacting with other humans. Instead the complex systems develops behaviour that due to chaos can not be inferred from knowledge of interaction of parts.
Example; altruistic attitudes.
  • #150
PeroK said:
I'm not sure who said people weren't made of particles.
Indeed.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
