Collision between photon and atom
Photon absorption is primarily considered an inelastic process, as it involves the transfer of energy from the photon to the atom, resulting in a change in the atom's energy state. Under resonant conditions, the absorption can be viewed as elastic scattering, depending on the decay channels of the excited electron. The definition of elastic collisions implies that the total energy remains constant, which does not hold true for photon absorption. If a photon is absorbed and another photon of the same energy is emitted immediately, the overall process may be regarded as elastic. Ultimately, the classification of photon absorption depends on the specific conditions and context of the interaction.
kmarinas86
Is photon absorption an elastic or inelastic collision? neither?
Under resonant conditions you can look at the absorption process as an elastic scattering event and as an inelastic one while off resonance. On resonance it also dependends on what decay channels the excited electron has.
The term "elastic collision" usually refers to a two-body scattering where each body has the same final energy in the center of mass system as its initial energy. With this definition, absorption is an inelastic process.
If the photon is "absorbed" it means that its energy is totally or partially transferred to the absorbing system, so the process it's inelastic by definition. However, if another photon of the same energy is emitted immediately after the absorption, the overall process can be considered as elastic.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
