Question 3B Part II: Buckling or Crushing? Joe Seeks an Explanation
In summary, the lesson discusses the two modes of compression failure, and the minimum E.S.R. for which buckling occurs.
Joe85
29
Hi all, the question has been posed many times, unfortunetly, there does not seem to be any explanation for finding the mode of buckling in Question 3B part ii, hence we i am posting.
1. Homework Statement
Below in image
Also elow in image
The lesson mentions that:
The minimum E.S.R. for which buckling occurs, is the one when the critical stress σc equal to the yield stress of the material σy. For a mild steel with E=200GPa and σc=σy=240MPa, the slenderness ratio is about 91. That means when effective slenderness ratios are less than 91 crushing is the failure mode, for values above 91 buckling is the mode.
I hvae taken this to mean:
E.S.R = 118.74
Slenderness Ration = L/K = 5.94/25*10^-3 = 237.6
Since the Slenderness Ratio of the column is 237.6 and the ESR is <237.6 the column is short and the mode of failure would be Crushing.
Am i barking up the wrong tree with this?
I have
A = 2199.11*10-6M2
K= 25x10-3M
I=1374446.9*10-12M4
E=200*109Nm-2
Oy=140*106Nm-2
E.S.R = √π2(200*109)/140*106 = 118.74
OR
Is it really as simple as saying that it could be either, since the minimum length that buckling can occur is 5.94m, which just so happens to be the length of our column.
Similarly for Part C, since we have now halved the length of the column, we are well below the minimum length for buckling, so it must be crushing?Thanks in advance.
Joe.
Since i’m new here I’m not sure what to make of the lack of replies. Is the solution that obvious that people aren’t wasting effort explaining it or that my question is so poorly posed that people don’t want to waste time trying to decipher it ... :) Probably the latter.
Sorry to come across as ungrateful and impatient but i stumbled across the formula for the “critical slenderness ratio” and am wondering if it is at all relavant to the question?
Thanks in advance.
Sorry I can't solve your first post, definitely not my field!
As for the second post, it often takes a few days for someone with specific knowledge to notice and answer any given post, especially on a weekend!
Meanwhile you might look at the information under the "INFO" link that is in the banner at the top of each page. It may explain the organization here a little bit better.
Anyhow, Welcome To PF Joe, glad to have you.
Cheers,
Tom
Likes PhanthomJay and Joe85
Cheers,
Tom
Top man, thanks Tom.
Your questions are well founded.
There are 2 modes of compression failure, either by buckling if the column is long enough, or crushing if it is short enough.
When the problem asks for minimum length for buckling to occur, it means that the critical buckling stress is right at the yield stress. That answer is 5.94 m which I assume you are comfortable with. That means that the column is right on the verge of either buckling or crushing. If it is 5.93 m, it will crush, if it is 5.95 m, it will buckle. Well at least in theory. No need to get back into slenderness ratios. When the length is halved, it is much smaller than the min length for buckling, so it will crush when that load is applied. That load is simply the load at yield stress...cross section area times yield stress.
Likes Joe85 and berkeman
Thank you, PhantomJay. Very much appreciated.
Likes berkeman
Related to Question 3B Part II: Buckling or Crushing? Joe Seeks an Explanation
1. What is buckling and crushing?
Buckling and crushing are two types of structural failure that occur when a material or structure is subjected to compressive forces. Buckling is the sudden bending or deformation of a material due to compressive stress, while crushing is the gradual collapse or failure of a material due to excessive compressive stress.
2. What causes buckling and crushing?
Buckling and crushing can be caused by various factors, including inadequate design or construction, excessive loads, material defects, and environmental conditions such as temperature and moisture. They can also occur due to changes in the shape or geometry of a structure, such as a sudden decrease in cross-sectional area.
3. How can buckling and crushing be prevented?
To prevent buckling and crushing, it is important to carefully consider the design and construction of a structure, ensuring that it can withstand the expected loads and environmental conditions. Using high-quality materials and regularly inspecting and maintaining the structure can also help prevent these types of failures.
4. What are the consequences of buckling and crushing?
The consequences of buckling and crushing can vary depending on the severity of the failure and the type of structure involved. In some cases, it can lead to minor damage or inconvenience, while in others it can result in catastrophic collapse and loss of life. It can also have significant financial implications, such as costly repairs or lawsuits.
5. How is buckling and crushing studied and analyzed?
Buckling and crushing can be studied and analyzed through various methods, including mathematical models, computer simulations, and physical testing. Engineers and scientists use these methods to determine the factors that contribute to buckling and crushing and to design structures that can withstand these forces.
9K
