Combinatorics: Creating a Sum of 1's and 2's with Repetitions Allowed
  • Thread starter Thread starter majestrooo
    Combinatorics Sum
The discussion revolves around finding the number of ways to create a sum k using integers 1 and 2, with repetitions allowed, under the constraints n ≤ k ≤ 2n. Participants explore different approaches to derive a solution, including rewriting the sequence and considering combinations of values for x_i. One participant suggests a formula derived from trial and error, n over k-n, to calculate the number of ways based on the counts of 1's and 2's. The conversation emphasizes the need to formalize the selection process for the remaining terms once the first term is chosen. Overall, the thread seeks clarity on combinatorial methods to solve the problem effectively.
majestrooo
In how many ways can we create the sum
k = x_1 + x_2 + ... + x_n
where each x_i is either 1 or 2 with repetitions allowed. n <= k <= 2n
For example
n = 4
k = 5
1+1+1+2
1+1+2+1
1+2+1+1
2+1+1+1
are four ways.
Is this solving the number of multisets (bags) and ordering them?
A few failed attempts :(
Let's see 'em!
Avodyne said:
Let's see 'em!
Heh allright! Didn't thought they would be of any interest, since I didn't get any far.
Anyway I have tried to rewrite the the sequence k = x_1 + ... + x_n
in different forms.
only this one I felt was kind of near the solution...
a_i = x _i + i .
Which means I should try to find the number of sequences a_i.
But this yields an increasing sequence
2 <= a_1 <= a_2 <=. ... <= a_n <= 2 +n
< = > 0 <= a_1 <= a_2 <=. ... <= a_n <= n
since according to my lecturer, the numbers of above sequences are given by (n+k-1) over k. So that's why I tried to rewrite it like that. But I don't know where to go from there, or if that's really the right approach.
Is this attempt good enough? :)
Try working out the possible combinations for x_1, then once you pick x_1, how many combinations do you have for x_2,...?
I'll use your example, for the first one you have two possibilities, 1 and 2 (3 would mean you can't have n=4). If x_1=1 then x_2+x_3+x_4=5-1=4, if x_1=2 then x_2+x_3+x_4=5-2=3. The first case gives 3 cases (you can make one of the x_2,x_3,x_4 = 2), the second gives one case. In total you have 4 ways of doing it.
Now try it for n and k.
But I don't know where to fit in n .
if
x1 = 1 then x2+x3+...+xn = k-1 (n-1 x left to choose)
OR
x1 = 2 then x2+x3+...+xn = k-2 (n-1 x left to choose)
The n-1 can be chosen in how many ways? Because the choice for x2 is as you said depending on if x1 = 1 or 2 and also the value of k (remember: n <= k <= 2n) . So how do I formalise that?
if x1 = 2
x2=1 then x3+...+xn = k-2-1
x2=2 then x3+...+xn = k-2-2
(n-2 x left to choose)
How do i choose the rest n-2 ??
etc
Help greatly appreciated:smile:
Ok I've reached a formula by trial and error hehe :)
n over k-n .
But can anyone help me with answering my previous post?
Suppose you were told that the sum consisted of n_1 1's and n_2 2's. Could you then answer the question of how many ways there are to create the sum?
Then, given n_1 and n_2, what are k and n?
  • · Replies 25 ·
