Combine bluetooth transmitter in a school project
The discussion centers on integrating Bluetooth technology into a school project, specifically focusing on building a Bluetooth transmitter. The participants recommend using Arduino microcontrollers with Bluetooth capabilities and suggest resources like Wikipedia for foundational knowledge. They clarify that while building a Bluetooth module from scratch is complex due to licensing and technical requirements, using pre-made modules like Zigbee is a practical alternative. Understanding electronic components such as resistors and capacitors is essential for designing a transmitter/receiver.
  • Basic knowledge of Arduino microcontrollers
  • Understanding of Bluetooth technology and its protocols
  • Familiarity with electronic components (resistors, capacitors, transistors)
  • Ability to read and interpret datasheets
  • Research Arduino Bluetooth modules and their applications
  • Study Bluetooth communication protocols and standards
  • Learn about Zigbee modules and their integration into projects
  • Explore resources on building and testing RF transmitters
Students in electronics courses, hobbyists interested in Bluetooth technology, and anyone looking to build wireless communication projects.
reonem
hey
im in 11th grade and I am in a electorinc trend at school, we have to make a project for school and i want to combine bluetooth technology in it.
i looked i looked Through the internet for guilding- how it is built, are there any protocols, how to use / transmit/recive - everything.
so far i have found only few datasheets.
(the project has to be submitted next year)
anyone here knows a site that teaches this subject?
thanks a lot.
reonem said:
hey
thanks a lot.
Welcome to the PF.
Here is an Arduino microcontroller (uC) board with Bluetooth capability:
http://www.arduino.cc/en/Main/ArduinoBoardBluetooth
You could probably base your project on that module, and come up with some good IO that you can control via the BlueTooth wireless path.
And the Wikipedia intro tutorial to BlueTooth looks pretty good:
http://en.wikipedia.org/wiki/Bluetooth
hi
thanks but the circuit in arduino site is a completed one with a mini processor- i am looking for a guide that teaches how to build a circuit like this- how to transfer data through a bluetooth transmiter, how the radio waves works- do you know a site that teaches it or it is to comlicated to learn online?(if there is a site that teaches it is not matter if it is complicated)
reonem said:
hi
The wikipedia page is a good place to start learning more. And if you follow the links out of that article, you can learn quite a bit more detail.
BlueTooth modules are available separately, so you don't need to buy it already combined with a uC. You probably are not going to be building a BlueTooth module yourself from scratch, though. At the very least, there are licensing requirements that you need to go through with the BlueTooth folks if you want to build something to their standard from scratch.
ahh ok
i got confused then
i thought the bluetooth is the method itself
is it possible to transmit data through short lengh radio wave with a home-made transmitter?
reonem said:
ahh ok
i got confused then
Yes, but see my post #12 in this other thread:
https://www.physicsforums.com/showthread.php?t=611869
You have to be fairly skilled and have adequate test equipment in order to avoid causing EMI with your hand-built transmitters...
is it possible to generate a stable frequent without understanding the billion laws arround it such as Coulomb and Lenz's law (and about 20 more)?
if so what laws and principles are necessary to know and what arent(the explanations of wikipedia are too complicated)?
someone?
If you want to design a transmitter/receiver, you don't need to know the physics, but you must know how the electronic components work together.
(That makes sense in my head, but if it isn't clear, I'll try again.)
you mean like ready components that can transmit a signal?
Who are you responding to?
(It's easier to keep things straight within a message thread if you use the "quote" feature: Click the QUOTE button on the message you wish to reply to.)
ah ok
i sent that message before to you
I was specifically referring to discrete electronics -- resistors, capacitors, transistors, inductors, etc. If you buy a ready-made transmitter module, then you really aren't "designing" a transmitter.
From a practical standpoint, using something like a Zigbee module to add Bluetooth to a project is the way to go.
