Common collector vs Common drain amplifier
7 replies · 17K views
boredaxel
I was wondering what's the main advantage of choosing one over the other, besides common drain having to suffer body effect. How do we determine if a CC is better or a CD is better to use as a buffer?
You would use a common drain amplifier if you were using a FET. If you had a BJT transistor, you would use a common collector circuit.
Both have slightly less than unity gain (gain < 1 ) and low output impedance, so they are used as buffer amplifiers.
Common collector:
Common drain:
The main operational difference (at least in my mind) is that FET's are Voltage controlled devices, whereas BJT's are current controlled devices.
With Vcc=5 volts, BJTs (common collector) work much better than NMOSs (common drain).
Bob S
The threshold of a FET is several volts, but only 0.65V for a bjt. If the input is 10V, the FET will output around 7V, where as the bjt will output 9.35V. For low voltages, the FET threshold is a problem. As Bob. S, stated, when the voltage is LOW, the bjt is a better choice since it drops much less voltage.
Claude
You wouldn't use an enhancement mode FET as a common drain amplifier. They do have a large threshold voltage.
Something like an MPF102 actually requires a negative voltage on the gate (relative to the source) to bias it.
This makes the biassing a little more complex as a large source resistor may be needed for the load but a smaller one may be needed for the biassing. So, such circuits often have both.
They have a small bypassed source resistor for bias purposes and a larger unbypassed one for the load. A gate resistor takes the voltage between the two to the gate.
However FETs perform badly at low voltages as Bob S has pointed out.
The high input impedance of an emitter follower is surprising if you haven't seen it before and it certainly becomes a voltage driven device.
If the supply voltage is 10 volts or so, which one you use doesn't make much difference to the performance.
vk6kro said:
[Something like an MPF102 actually requires a negative voltage on the gate (relative to the source) to bias it.
Finally getting back to the "good ol' days" of the familiar cathode bias circuits.
Bob S
Thanks everyone for the input!
