Common emitter transistor configuration
amaresh92
would you please tell me,in common emitter transistor configuration what is the use of grounding the emitter?
thanks
The emitter doesn't have to be actually grounded, but it has to have a path for the base current and collector current to return to the negative supply (for an NPN transistor ) as emitter current.
Is that what you meant?
Or were you comparing it to the alternative of having an emitter resistor and then grounding that?
actually i don't have any idea why and when we ground any terminal as it seems to be in the case of ce configuration.
In the CE (common emitter) configuration, the base is the input and the output is the collector. There is a current gain from the base to the emitter, and a large voltage gain at the collector into a large load resistance when the emitter is grounded. In an npn transistor, the emitter is the source of both the base and collector electron currents when it is grounded.
Bob S
