Graduate Compute Commutator of Covariant Derivative & D/ds on Vector Fields
The discussion revolves around the commutation of the covariant derivative and the derivative with respect to the parameter s on vector fields defined along a family of geodesics. Participants point out issues with the definitions and notations used, particularly regarding the indices of the vector field Z and the nature of the parameter s. There is a consensus that the initial definitions need clarification, especially distinguishing between parameters and coordinates. The relationship between the induced connection along the curve and the covariant derivative is emphasized, with the key question being whether the derivatives commute. Ultimately, the conversation highlights the need for precise definitions in the context of differential geometry.
Pentaquark6
Hi, let ##\gamma (\lambda, s)## be a family of geodesics, where ##s## is the parameter and ##\lambda## distinguishes between geodesics. Let furthermore ##Z^\nu = \partial_\lambda \gamma^\nu ## be a vector field and ##\nabla_\alpha Z^\mu := \partial_\alpha Z^\mu + \Gamma^\mu_{\:\: \nu \gamma} Z^\gamma## be the covariant derivative. Let us lastly define
$$ \frac{\mathrm{D}}{\mathrm{d}s} Z^\mu (s):= \frac{\partial (Z^\mu \circ \gamma)}{\partial s}+\Gamma^\mu_{\:\: \alpha \beta} \dot{\gamma}^\beta Z^\alpha \\
=\dot{\gamma}^\beta \nabla_\beta Z^\mu$$.
Do the covariant derivative and ##\frac{\mathrm{D}}{\mathrm{d}s}## applied to a vector field commute in this case?
I tried verifying that they do, but I don’t know how to compute ##\frac{\mathrm{D}}{\mathrm{d}s}## applied to a tensor.
Likes Emil_M
Seems like you used wrong indices in defining ##Z##. The correct would be ##\nabla_\alpha Z^\nu = \partial_\alpha Z^\nu + \Gamma^{\nu}{}_{\alpha \sigma} Z^\sigma##. Considering you last defined quantity we would have a term of the type $$\nabla_\alpha \frac{\partial}{\partial s} \gamma_{\beta} \nabla^{\beta}$$ when calculating the commutator. And you would need to operate with the covariant derivative on the field ##\gamma## on that term. So it seems that they will not commute. PF members please tell me if I'm wrong.
Pentaquark6 said:
Let furthermore ##Z^\nu = \partial_\lambda \gamma^\nu## be a vector field
This can't be correct because the indexes don't match. If ##\gamma## is a scalar field, then ##\partial^\nu \gamma = Z^\nu## is a vector field. (Strictly speaking, the ##\partial## should have a lower index, so you would have a covector field ##\partial_\nu \gamma = Z_\nu##, and you could raise an index with the inverse metric to get the corresponding vector field.)
With the correct definition of a vector field, its covariant derivative looks like what @kent davidge posted in post #2.
However, even before we get to this point, I'm confused about what you intend ##\gamma## to be. You define it as:
Pentaquark6 said:
let ##\gamma (\lambda, s)## be a family of geodesics, where sss is the parameter and λλ\lambda distinguishes between geodesics.
But with this definition, ##\lambda## and ##s## aren't coordinates, they're parameters, so ##\gamma## isn't even a scalar field, and you can't compute its covariant derivative at all. A scalar field would be ##\gamma(x^\nu)##, i.e., a function that takes coordinates as input and outputs a number. To obtain that from your definition you would need functions ##\lambda(x^\nu)## and ##s(x^\nu)##, i.e., for every point in spacetime, you would need to know which geodesic in the family it was on and what the curve parameter of that geodesic was at that spacetime point. Without this information you can't proceed.
No, you wouldn't. As I noted above, ##\gamma## shouldn't have an index. Also, ##s## is a curve parameter, not a coordinate, so there is no meaning to a partial derivative with respect to it. The whole scheme in the OP needs to be reworked in the light of the above comments.
Likes kent davidge
Kent davidge: yeah you’re right, I’ve got a typo in the definition of ##\nabla_\alpha Z^\mu##.Ok, it seems that there is a conflict of notations here. In the text I am using, the points along a curve ##\gamma## are denoted as ##\gamma^\mu \partial_\mu## with ##\partial_\mu## being the basis vectors. This renders ##\gamma^\mu## (the components of) a vector field.
Furthermore ##Z^\mu=\partial_\lambda \gamma^\mu## shouldn't be a conflict of indices, as ##\lambda## is not an index denoting components, but a parameter by which ##\gamma## is differentiated. If this notation irritates you, we can write ##Z^\mu=\dot{\gamma}^\mu## with ## \dot{}=\frac{\partial}{\partial \lambda}##.
I hope this makes my question a little bit clearer.
Likes kent davidge
What text? And what part of it are you getting all this from?
May be this will help. The derivative ##\frac D{ds}## is the induced connection along the curve from ##\nabla##. So, at least for tensors that are restrictions along the curve from tensors on the manifold, you have that ##\frac D{ds}T=\nabla_{\dot{\gamma}}T##. Your question really is whether ##\nabla_X\nabla_{\dot{\gamma}}T=\nabla_{\dot{\gamma}}\nabla_XT##.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 124 ·
9K
  • · Replies 24 ·
  • · Replies 19 ·
