Commutators and solvable groups
Commutators are defined as ABA^-1B^-1, and a group is solvable if its derived series eventually reaches the trivial group. The Heisenberg group is two-step solvable, demonstrated by showing that the first commutator does not equal the identity while the second does. To prove that GL(2,R) is not solvable, one must compute the commutators of upper triangular matrices and show that it contains elements that do not lead to the identity. Additionally, a group is solvable if it has a subnormal series with all abelian quotient groups, while nilpotent groups have a stronger condition where G^i equals the identity for some i.
JSG31883
I am not really clear on what is meant by commutators. I know that the commutator of G is ABA^-1B^-1, but I am not sure how to check if a group is solvable by having the commutator eventually equal the trivial group.
For example, I know that the Heisenberg group of 3x3 upper triangular matrices is two-step solvable, but am not sure how to SHOW that. I know that it means that the first commutator doesn't equal the identity matrix and that the second one does... but how do I show this?
Also, how do I show that the group GL(2,R) (2x2 invertible matrices) IS NOT solvable?
you need to describe the commutator, so do it. take two arbitrary matrices in the upper triangular matrices and work out the commutator. see what happens. now take the commutator of this with another generic element of the comutator, see what you get. as it happens it is clearer to see that the lie algebra is solvable.
example: upper triangular 2x2 matrices with 1 on the diagonals, what is the commutator or two elements?
\left(\begin{array}{cc} 1&amp;a\\0&amp;1 \end{array}\right)\left(\begin{array}{cc} 1&amp;b\\0&amp;1 \end{array}\right)<br /> \left(\begin{array}{cc} 1&amp;-a\\0&amp;1 \end{array}\right)<br /> \left(\begin{array}{cc} 1&amp;-b\\0&amp;1 \end{array}\right)
well?
as for the second example, GL contains SL which is simple.
How can I show that the group G=<a,b,c> with [a,b]=b, [a,c]=1, [b,c]=1 is solvable but not nilpotent?
A group G is said to be nilpotent if G^i=identity for some i.
A group G is said to be solvable if it has subnormal series G=GncG3cG2cG1=identity... where all quotient groups are abelian.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
