What is the Relationship Between Force and Weight?
  • Thread starter Thread starter Northern Cardinal
    Force Weight
The discussion clarifies the distinction between force and weight, emphasizing that weight is a force measured in Newtons, while mass is measured in kilograms. The user initially attempted to calculate the ratio of force to weight using incorrect values, leading to confusion. The correct understanding is that weight is derived from mass multiplied by the acceleration due to gravity, specifically using the formula Weight = Mass × Gravity (where gravity is approximately 9.81 m/s²). The user successfully resolved their misunderstanding by recognizing this fundamental principle.
  • Understanding of Newton's Second Law of Motion
  • Basic knowledge of units of measurement (Newtons and kilograms)
  • Familiarity with the concept of gravitational acceleration
  • Ability to perform basic mathematical calculations
  • Study the relationship between mass, weight, and gravitational force using the formula Weight = Mass × Gravity
  • Explore Newton's laws of motion for a deeper understanding of force
  • Learn about the effects of gravity on different celestial bodies
  • Investigate common misconceptions in physics related to force and weight
Students studying physics, educators teaching basic mechanics, and anyone interested in understanding the fundamental principles of force and weight relationships.
Northern Cardinal
I need help figuring out c.
a) A 15.0-kg child is riding a playground merry-go-round that is rotating at 45.0 rpm. What centripetal force must she exert to stay on if she is 1.50 m from its center?
Correct answer: 499.649 N
b) What centripetal force does she need to stay on an amusement park merry-go-round that rotates at 3.00 rpm if she is 7.10 m from its center?
Correct answer: 10.511 N
c) Compare each force with her weight.
force from part (a) / weight = _______
force from part (b) / weight = _______
So here's what I've tried:
force from part (a) / weight = 499.649N / 15kg = 33.310
force from part (b) / weight = 10.511N / 15kg = 0.701
Apparently this wasn't correct. What am I doing wrong? I feel like I'm missing the obvious.
Likes Delta2
Mass is stated in kg. That's not weight. Weight is a force in Newtons.
Likes Delta2 and Northern Cardinal
Thanks! I was able to figure out the correct answer.
Likes Delta2
Excellent!
  • · Replies 32 ·
  • · Replies 24 ·
  • · Replies 38 ·
