Which Acid Has a Lower pH: HBrO4 or HIO3?
  • Thread starter Thread starter bomba923
    Ph
The discussion centers on the acidity and naming conventions of various iodine and bromine oxoacids, specifically comparing the strengths of HBrO4 and HIO3. Participants explore the naming of HIO4, questioning whether it should be termed periodic acid or metaperiodic acid, with references to IUPAC guidelines. There is confusion regarding the correct formula for periodic acid, with some sources citing H5IO6 and others HIO4. The conversation delves into the factors influencing acid strength, such as the oxidation state of the halide and the number of oxygen atoms attached. It is concluded that HBrO4 is likely the stronger acid due to its higher oxidation state and electronegativity compared to HIO3. The discussion also touches on the significance of prefixes like "meta-" and "para-" in chemical nomenclature, particularly in organic and inorganic contexts.
bomba923
Which is stronger (lower pH): {\text{HBrO}}_{\text{4}} or {\text{HIO}}_{\text{3}} ?
How would I name {\text{HIO}}_{\text{4}}-- Periodic acid, I suppose?
If perchoric acid is {\text{HClO}}_{\text{4}}, why then is periodic (per-iodic) acid {\text{H}}_{\text{5}} {\text{IO}}_{\text{6}} ? ( as on http://chemistry.about.com/cs/molecules/a/blperacid.htm )
Why does http://chemistry.about.com/cs/molecules/a/blperacid.htm and http://www.gfschemicals.com/chemicals/gfschem-74.asp say that periodic acid is {\text{H}}_{\text{5}} {\text{IO}}_{\text{6}} , but http://www.online-medical-dictionary.org/?q=Periodic+Acid+(HIO4) and http://www.catalogue.fisher.co.uk/scripts/search.dll?ViewMSDS&SheetNumber=19510 say that periodic acid is {\text{HIO}}_{\text{4}} ?
(I suppose {\text{HIO}}_{\text{4}} is metaperiodic acid, then?)
Finally, (it will be strong, no doubt, but) just how strong exactly would {\text{HIO}}_{\text{4}} be? (Safety Description (please)--cannot locate on web)
Chemistry news on Phys.org
For the terminology question,i think IUPAC gave clear rules...Look for them.
Daniel.
If perchoric acid is {\text{HClO}}_{\text{4}}, why then is periodic (per-iodic) acid {\text{H}}_{\text{5}} {\text{IO}}_{\text{6}} ? ( as on [/QUOTE] Did you mean or [tex] {...e not the number of water molecules involved.
DrMark said:
Did you mean or {\text{HIO}}_{\text{3}} or {\text{HIO}}_{\text{4}}
No--Actually, I wanted to see which would be most significant. The iodine with the oxygens in {\text{HIO}}_{\text{3}} greatly shifts electron density away from the hydrogen.
In {\text{HBrO}}_{\text{4}}, the same thing happens. However, we have a lighter halide with few electrons---but more oxygen attached to it!
Basically, what is more important: mass of the halide (molar mass, atomic number (more electrons means more electron density away from acidic hydrogen))...or, the number of oxygen attached to the halide?
Bromine is lighter than iodine, but has one more oxygen attached to it. In a test of acid strength, which would win: {\text{HIO}}_{\text{3}} or {\text{HBrO}}_{\text{4}} ?
(But as for my other question, IUPAC says periodic acid is {\text{HIO}}_{\text{4}} , but many websites seem to differ tho...)
Actually H5IO6 should be written as HIO4.2H2O.
The pKa of HBrO3 is -1.0 while that of HIO3 is .74 so yes HBrO4 is likely the stronger acid (couldn't find numbers on HBrO4). HBrO4 is in higher oxidation state (the halide that is) and has greater electronegativity, hence it should be the stronger acid.
Paraperiodic being H_{5}IO_{6} ? Highly unlikely.U need to compare the first acidity constant of both acids (actually,monoprotic acids have only one).
Daniel.
Yes--Paraperiodic acid is a weak polyprotic acid
But one more question tho:
In the context of naming chemicals, what do the prefixes "meta-" and "para-" indicate?
I think/hope it's clear for organic substances...(look for "benzene cycle").
As for inorganic,well,i'll let someone else more knowledgeable do the talking.
Daniel.
