Partial Differential Equations result -- How to simplify trig series?
The discussion revolves around a boundary value problem involving partial differential equations, specifically the heat equation, and the simplification of a series solution derived from it. The original poster presents a solution involving trigonometric series and seeks clarification on the simplification steps and the role of certain variables.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the derivation of the series solution and the simplification process, questioning the validity of certain steps and the assumptions made regarding the sine function's values at specific intervals.
Some participants have offered insights into the patterns observed in the sine function and its implications for the series. There is ongoing exploration of the correctness of the simplifications presented by the instructor, with multiple interpretations being considered.
Participants note the importance of understanding the underlying concepts of the ordinary differential equation involved and the implications of boundary conditions on the solution. There is also mention of grading criteria related to the simplification of series, which adds pressure to verify the correctness of the steps taken.
AnotherParadox
Solve the Boundary value problem
[itex]u_{t}=u_{xx}[/itex]
[itex]u(0, t) = u(\pi ,t)=0[/itex]
[itex]u(x, 0) = f(x)[/itex]
[tex]f(x)=\left\{\begin{matrix}
x; 0 < x < \frac{\pi}{2}\\
\pi-x; \frac{\pi}{2} < x < \pi
\end{matrix}\right.[/tex]
[tex]u(x, t) = \sum_{n=1}^{\infty} A_{n} \exp(- \lambda t)\sin(\sqrt{\lambda}\cdot x))[/tex]
[tex]A_{n}=\frac{2}{L}\int_{0}^{L}f(x)sin(\sqrt{\lambda}\cdot x)dx[/tex]
Solve the boundary value problem
Given
u_{t}=u_{xx}
u(x, 0) = f(x)
f(x)=\left\{\begin{matrix}<br /> x; 0 &lt; x &lt; \frac{\pi}{2}\\<br /> \pi-x; \frac{\pi}{2} &lt; x &lt; \pi<br /> \end{matrix}\right.
L is π - 0=π
λ = α2 since 0 and -α lead to trivial solutions
Let
u = XT
X{T}&#039;={X}&#039;&#039;T
\frac{{X}&#039;&#039;}{X}=\frac{{T}&#039;}{T}=-\lambda
{X}&#039;&#039;+\lambda =0
X(0)=X(\pi)=0
{T}&#039;+\lambda T=0
X(x)=C_{1}\cos (\sqrt{\lambda }\cdot x)+C_{2}\sin(\sqrt{\lambda }\cdot x)
\sqrt{\lambda } \cdot \pi = n\pi
\lambda =n ^{2}; n=1,2,3,..
{T}&#039;+n^{2}T=0
(I'm not entirely sure how t got into this next step, I know T is actually T(t) but still not sure what it's doing in the next step with the exponential)
T(t)=C_{3}\exp (-n ^{2}t)
u_{n}(x,t)=C_{2}C_{3} \exp(-n^{2}t)\sin(nx)=A_{n} \exp(-n^{2}t)\sin(nx)); n = 1, 2, 3, ..
u(x, t) = \sum_{n=1}^{\infty} A_{n} \exp(-n^{2}t)\sin(nx))
u(x,0)=f(x)
A_{n}=\frac{2}{\pi}\left [\int_{0}^{\pi/2}x\sin(nx)dx + \int_{\pi/2}^{\pi}(\pi-x)\sin(nx)dx \right ]
=\frac{2}{\pi}\left [\left [ \frac{x(-\cos(nx))}{n} \right ]_{0}^{\pi/2} + \int_{0}^{\pi/2} \frac{\cos(nx)}{n}dx + \left [\frac{(\pi-x)(-\cos(nx))}{n} \right ] _{\pi/2}^{\pi} - \int_{\pi}^{\pi/2}\frac{\cos(nx)}{n}dx \right ]
=\frac{-1}{n}\cos (\frac{n \pi}{2}) + \frac{2}{\pi n^{2}}\sin(\frac{n \pi}{2}) + \frac{1}{n}\cos (\frac{n \pi}{2}) + \frac{2}{\pi n^{2}}\sin(\frac{n \pi}{2})
=\frac{4}{\pi n^{2}}\sin(\frac{n \pi}{2})
u(x, t) = \sum_{n=1}^{\infty} \frac{4}{\pi n^{2}}\sin(\frac{n \pi}{2}) \exp(-n^{2}t)\sin(nx))
Ok so far so good. An was found and put back into the general form of the solution.
Here's where it gets tricky
Apparently there is further simplification of this, now these next steps were provided to me by my instructor (as were the previous too) during lecture and I cannot make sense of them. I see what is supposed to happen, cos and sin follow a pattern on intervals of π or nπ where they evaluate to predictable values like 1,0,-1 etc. and we can ignore some values because they lead to all 0s or the trivial solution.
Apparently he continues by the following steps
<br /> u(x, t) = \sum_{k=0}^{\infty} \frac{4}{\pi (4k+1)^{2}}\exp(-(4k+1)^{2}t)\sin((4k+1)x)) -\sum_{k=0}^{\infty} \frac{4}{\pi (4k+3)^{2}}\exp(-(4k+3)^{2}t)\sin((4k+3)x))
Separated into two series and replaced n with 4k+1 and 4k+3, eliminated the first trig function with some version of previously stated pattern recognition and started the series at 0 instead of 1
Now I can't even verify if this is equivalent to the other series let alone figure out the pattern or logic to this to figure it out for other scenarios.
And someone stated that it can be reduced further into
<br /> u(x, t) = \sum_{k=0}^{\infty} (-1)^{k}\exp(-(2k+1)^{2}t)\sin((2k+1)x))<br />
If someone can please break it down and explain how this is done I will be very grateful as the exam is soon and I cannot seem to figure out how to follow the process to come up with these series reductions
Thank you!
Also it would be nice to know how t ends up in this step{T}&#039;+n^{2}T=0
but not nearly as important.
Thanks again
What values can ##\sin(n\frac\pi 2)## take?
For each such value, what values of n produce that result?
AnotherParadox said:
Also it would be nice to know how t ends up in this stepT′+n2T=0T′+n2T=0{T}'+n^{2}T=0
T(t)=C3exp(−n2t)T(t)=C3exp⁡(−n2t)T(t)=C_{3}\exp (-n ^{2}t)
This is just solving a first order ODE in ##t##. Clearly the result must depend on ##t## unless ##T’ = 0## or you have a trivial solution.
Having taught and authored a book on this subject, I would say that if you have an exam soon then understanding this would be far more important than being able to simplify the resulting expressions.
Edit: Rereading this I see an ambiguity in my phrasing so just for clarity: I did not teach the book, I taught students ...
Thanks for the response
Here's my thought process
It can't take 0 since sin(0*pi/2) and sin(0*x) is 0 and that leads to the trivial solution.
It can take 1 since sin(1*pi/2) does not equal 0 it equals 1
It can't take 2 since sin(2*pi/2) = 0 and the trivial solution
It can take 3 since sin(3pi/2) = -1 and not zero
It can't take 4 since sin(4pi/4) = 0 and the trivial solution
So I know it can't take any even number since they all lead to 0 and thus the trivial solution
Odd numbers i.e. n = 1, 3, 5, 7.. lead to the pattern 1, -1, 1, -1
Which is a similar pattern as (-1)^n which is for n = 0, 1, 2, 3,: 1, -1, 1, -1
So this can be (-1)^(n) which is for n = 0, 1, 2, 3: To match that part of the expression
Evaluating the rest of the series 2k+1 is needed instead of n is needed so that it's 1,3,5,7 for the 0,1,3,4.. I see how this logic was applied to come up with the 4k+1 and 4k+3 so that checks out too now
So far so good however I think he may of made a mistake and I would like confirmation of this
So he changes
to
<br /> u(x, t) = \sum_{k=0}^{\infty} \frac{4}{\pi (4k+1)^{2}}\exp(-(4k+1)^{2}t)\sin((4k+1)x) -\sum_{k=0}^{\infty} \frac{4}{\pi (4k+3)^{2}}\exp(-(4k+3)^{2}t)\sin((4k+3)x)
I think this checks out and the series match however on the next reduction I think a few things are left out because he shows
<br /> u(x, t) = \sum_{k=0}^{\infty} (-1)^{k}\exp(-(2k+1)^{2}t)\sin((2k+1)x)<br />
Which looks even better but I believe it's missing the front part and it should be<br /> u(x, t) = \sum_{k=0}^{\infty} \frac{4}{\pi (2k+1)^2} (-1)^{k}\exp(-(2k+1)^{2}t)\sin((2k+1)x)<br />
Or even more
u(x, t) = \frac{4}{\pi} \sum_{k=0}^{\infty} \frac{1}{ (2k+1)^2} (-1)^{k}\exp(-(2k+1)^{2}t)\sin((2k+1)x)
If anyone can confirm this and/or tell me about other short-cuts/quick verifying tricks/ and ways of thinking that would be much appreciated.
Np, I understood what you meant, thanks for the response.
Here's my work
{T}&#039;+n^2T=0
{T}&#039;=-n^2T
\frac{{T}&#039;}{T}=-n^2
\ln\left ( \frac{{T}&#039;}{T} \right )=-n^2
\int \left ( \frac{{T}&#039;}{T} \right )=\int-n^2dt
I'll stop here since I figured it out. the -n^2 has to be integrated with respect to t which multiplies t in. Though it makes me wonder why not with respect to n. I suppose for the boundary conditions it needs to be t? I kind of see what is being said with T'=/=0
I agree it's more important to understand this ODE but I can easily write in the correct step and receive full credit but he counts off significantly for not reducing the series if I understand his grading correctly.
I agree, he seems to have dropped the factor ##\frac 4{\pi}##.
Also the term for 1/(2k+1)^2, right?
Ah, yes... and that's worse.
Because the derivative is with respect to t while n is a constant.
This is really bad pedagogy if it is correct.
I like this reasoning
Here's some work I thought up with considering this more
{T}&#039;+n^2T=0
\frac{{dT}}{dt}+n^2T=0
\frac{{dT}}{dt}=-n^2T
\frac{\frac{{dT}}{dt}}{T}=-n^2
\int \left ( \frac{dT}{T} \right )=\int-n^2dt
from there it's ln -> exp
Let me know if this checks out
I agree. I wasn't aware of how bad it was though. To be fair it is not a math major course, it's an engineering elective (still important imho). I could very well leave out a lot of these steps entirely and not be counted off however the reduction portion could be anywhere to 10%-30% of the question worth. He often teaches from memory (impressively) and makes mistakes that don't get corrected until I look over the class notes on my own which can be awfully difficult at times (wish he would check /confirm his answers from a record). Still a decent teacher, just a bit aged and dated in his ways. Also different standards for non math majors I suppose.
Yes. The more standard approach is to assume ##T = C e^{rt}## and inserting into the differential equation to solve for ##r##, but what you did is certainly fine and does not depend on an ansatz.
