Completing the Square: Solving Multivariable Equations
  • Thread starter Thread starter Ted123
    Square
Ted123
How do I complete the square for: x^2 + 2y^2 + 2z^2 + 4xy +4xz + 4yz
I can do it for a normal quadratic ax^2 + bx + c but how do I do it for something like this with more than one variable?
I doubt that there is one particular "correct" result for this.
Notice that this polynomial does contain a perfect square for two of the variables, y & z: 2y^2+4yz+2z^2=2(y+z)^2\,.
Factor 4x out of the two remaining "mixed" terms.
x^2+4x(y+z)+2(y+z)^2​
I see two ways to finish. You can figure out how many terms of (y+z)2 to add & subtract, or you can figure out how many terms of x2 to add & subtract. The latter way gives a simpler looking answer.
I've got it equal to the sum of squares: 2(x+y+z)^2 - x^2 What does this mean the rank and signature is? There is 1 positive square and 1 negative square so is the rank 1+1=2 and the signature 1-1=0?
You can apply (essentially) the algorithm that leads to Cholesky factorization of a matrix. In your example, start by looking at the x-terms, which are x^2 + 4xz + 4yz . These are what you would get if you looked at (x+2y+2z)^2, because that is where you would get terms of the form 4xy and 4xz. Anyway, we have x^2 + 4xy + 4xz = (x+2y + 2z)^2 - 4y^2 - 4z^2 - 8yz,, so your function f(x,y,z) is
(x+2y+2z)^2 -2y^2 - 2z^2 -4yz. Now 2y^2+2z^2+4yz = 2(y+z)^2,
so we finally have f(x,y,z) = (x+2y+2z)^2-2(y+z)^2.
RGV
RGV
So is the rank 2 and the signature 0?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
