Complex functions with a real variable (graphs)
11 replies · 2K views
Poetria
How do the values of the following functions move in the complex plane when t (a positive real number) goes to positive infinity?
y=t^2
y=1+i*t^2[/B]
y=(2+3*i)/t
I thought:
y=t^2 - along a part of a line that does not pass through the origin
y=1+i*t^2 - along a part of parabola
y=(2+3*i)/t - along a part of hyperbola
Unfortunately everything is wrong. I understand that e.g. y=1+i*t^2 is a line =1 and a parabola but I don't know how to connect it. Could you give me a hint how to visualise this?
Other possibilities: spirals inward/outward, clockwise/counterclockwise, along a circle, radially inward/outward
[/B]
With ##t## as a parameter, you are not plotting ##y## against ##t##, but simply the locus of ##y## in the plane.
I am trying to imagine it. So e.g. t^2 would move counterclockwise along a circle? (Moving parabola?)
I got the second one right, moving along part of a line... Wow! I am beginning to understand.
Note that for the first locus ##y## is always real.
Is it simply a parabola in this case?
As for the third I guess it spirals clockwise inward as t^(-1).
Why not simply plot ##y##? You seem to be still thinking that you are plotting real ##y## against real ##t## on a normal 2D graph. That's not the case at all.
You are plotting a single complex number ##y## as its value changes.
If ##y## is real then it is confined to the real line and cannot be a parabola!
No. In particular, I'm not sure how you got the clockwise motion?
Perhaps there would be less confusion for the OP if the variable had been called ##z## instead of ##y##. Especially since complex numbers are usually expressed as ##z = x + iy##. Pretty poor notation for the problem if you ask me.
Thank you very much for your patience. :)
I tried plotting and got the third right.
Ok. I got all the three right. Phew. It is very simple in fact. :(
