Complex power calculations formula
4 replies · 22K views
FrankJ777
I'm confused about a point concerning complex power calculations. The formula my text gives is S=V(eff)I(eff)*. I'm confused about what the conjugate is for I(eff). The way I understand it, I(eff) = I(rms) and I(rms) = I(m)/√2. Since I(m) is a real number, and I(m)/√2 is real, how is there a conjugate.
For example:
i(t)= 20cos(ωt+165)
I(m)=20
I(eff)=20/√2
...so what is I(eff)*?
I've read through the textbook book the only examples that I can find use the equation: S=(1/2)VI*.
I would be grateful for any help you could provide to help me understand this.
Hi FrankJ777! :smile:
Complex power is supposed to be complex.
For a perfect resistor, the complex power is purely real,
and for a perfect capacitor or inductor, it's purely imaginary …
but for a mixture, it'll be "genuinely complex", but with a constant phase …
(because we assume the current leads the voltage by a constant phase, and so 1/2 VI* subtracts the two phases, and keeps the total phase constant :wink:) …
I think :redface:
If
V(t) = Vmax exp[jwt + phi] and
I(t) = Imax exp[jwt + phi] then
S = (1/2) V(t) I(t)* is the rms real power.
But even if you use rms values, you still have both volt-amps and watts.
Also...
v(t) = Vmax/ exp[jwt]
i(t) = Imax exp[j(wt + phi)]
Veff (phasor) = v(t)/√2
Ieff (phasor) = i(t)/√2
I*eff = Imax/√2 exp[-j(wt + phi)] (note minus sign)
so (product of phasors)
Veff x I*eff = Vmax/√2 exp[jwt] x Imax/√2 exp[-j(wt + phi)]
Seff = Vmax Imax/2 exp (-jphi)
(plus exp of voltage time and minus exp of current conjugate time cancel, leaving only phi part, that's why conjugate is right for this)
real power P = Real {S} = Veff Ieff cos (-phi)
reactive power Q = Imag{S} = Veff Ieff sin (-phi)
(so 'Reactive Power' is negative for inductive circuits where phi is positive)
the phasors make a vector triangle:
S^2 = P^2 + Q^2
Sorry the formatting is not better. Still, I hope this helps.
Welcome to PF!
Hi Dr.kW! Welcome to PF! :smile:
(have a phi: φ and an omega: ω and try using the X2 and X2 tags just above the Reply box :wink:)
Action replay (of Dr.kW :wink:):-
v(t) = Vmax/ ejωt
i(t) = Imax ej(ωt + phi)
I*eff = Imax/√2 e-j(wt + φ) (note minus sign)
Veff x I*eff = Vmax/√2 ejωt x Imax/√2 e-j(ωt + φ)
Seff = Vmax Imax/2 exp-jφ
(plus exp of voltage time and minus exp of current conjugate time cancel, leaving only φ part, that's why conjugate is right for this)
real power: P = Real {S} = Veff Ieff cos (-φ)
reactive power: Q = Imag{S} = Veff Ieff sin (-φ)
(so 'Reactive Power' is negative for inductive circuits where φ is positive)
S2 = P2 + Q2 :wink:
