How do I convert 1.13 x 10^5 km/h^2 to m/s^2?
  • Thread starter Thread starter Champ07
To convert 1.13 x 10^5 km/h² to m/s², it is essential to address the units correctly, particularly the h². The conversion involves recognizing that 1 hour equals 3600 seconds, which affects both the numerator and denominator. The correct conversion process requires multiplying by the appropriate factors to change hours to seconds, specifically using 1 hr² = (3600 sec)². The final conversion should yield the result in m/s². Understanding unit conversions is crucial for accurate calculations in physics.
Champ07
1.13 * 10^5 km/h^2 to km/h * s
1.13 * 10^5 km/h^2 to m/s^2
None
I'm not sure how to convert these because of the h^2 that's really screwing me up.
Never mind I think I've figured it out anyway
Well in case you still didn't get it:
\frac{1}{hr^2} * \frac{1 hr}{3600 sec}
If you post help, please get it right, should read:
\frac{1}{hr^2} * \frac{1 hr^2}{3600 sec^2}
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
