Calculating Correlation of Composite Operators
geoduck
I have probably a silly question about correlation functions of composite operators. Why can't you just calculate a correlator with fields at different points x1, x2, x3, ... and then set a couple of the points equal at the end of the calculation to get the result?
e.g.,
\langle 0 T\phi(x_1)\phi(x_2)... 0\rangle
and to have a phi^2 composite operators just set x1 equal to x2 at the end of the calculation?
When you calculate \langle 0 T\phi(x)\phi(y)... 0\rangle perturbatively at least, it seems the result is a fairly simple function of x and y. You'll get something like:
constant*eikx*eiqy
where k and q are integrated over. So just set x=y above?
The problem is that when you are dealing with quantum operators, the ordering as y -> x becomes ambiguous. In your "constant," you have creation and annihilation operators which do not commute in the limit, and you need a prescription for dealing with them. It turns out that the normal ordering prescription is an unambiguous way to take the limit:
<br /> :\phi(x)^2: = lim_{x \rightarrow y} \{ \phi(x) \phi(y) - \langle \phi(x) \phi(y) \rangle \} <br />
I was thinking in terms of a functional integral approach rather than an operator approach, so I wouldn't have to worry about operators and commuting.
But in terms of the operator approach, I've seen people try this:
&lt;T\phi(x+\epsilon)\phi(x-\epsilon)&gt;
so by arbitrary choice, the first phi is set at a later time. Then the limit ε is taken zero.
Are correlators of noncomposite operators analytic in the coordinates? It's just weird that you can't set two of the coordinates equal at the end of the calculation.
Well the functional integral is equivalent to a quantum time-ordered operator. In either case, you're going to get some divergence, either in coordinate space from x=y, or in momentum space from a UV divergent momentum integral.
I think your intuition isn't right - in general one expects operator products to be divergent at the same space-time point, and this is why loops diverge (the integration diverges where the operators overlap). Recall that time-ordered correlators can be decomposed into propagators by Wick's theorem, and propagators are Green's functions of the Klein-Gordon equation. Such functions are clearly divergent at small distances (though maybe not in d=1?).
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
