Compressed Air Turbine: A Sustainable Solution for Power Generation
The discussion focuses on the feasibility of using compressed air turbines for power generation, with participants exploring various turbine types and manufacturers. It highlights that many turbine designs can operate on compressed air, including rotary vane pumps and Tesla turbines. However, concerns are raised about the efficiency and practicality of generating electricity from compressed air compared to directly using the original energy source, such as diesel or wind. A participant also expresses interest in the thermodynamic aspects of compressing and releasing air, prompting a suggestion to start a new thread for that specific inquiry. The thread concludes with a lock due to the shift in topic.
pranj5
I don't know whether this is appropriate for this part or not, but I am now looking for turbine/machinery that can be run by compressed air to produce power/electricity. Is there any manufacturer of such a machine is available?
Are you referring to something like a gas turbine ?
No. A turbine that will run on compressed air.
Pretty much any turbine will work. Being air (low temp, non corrosive/reactive) opens up a lot of options.
A https://www.amazon.com/dp/B0002YVBK2/?tag=pfamazon01-20 converts compressed air into shaft power, that could be coupled with a very small generator.
For a bit more power there are larger options, some I've read about in small ORC systems:
http://waset.org/publications/6420/efficiency-of-compact-organic-rankine-cycle-system-with-rotary-vane-type-expander-for-low-temperature-waste-heat-recovery (An engineering student at MIT adapted a used car aircon pump, can't find the paper right now).
https://en.wikipedia.org/wiki/Rotary_vane_pump
Tesla turbine
https://en.wikipedia.org/wiki/Tesla_turbine
Screw compressor
https://en.wikipedia.org/wiki/Rotary-screw_compressor
Scroll compressor
https://en.wikipedia.org/wiki/Scroll_compressor
http://organicrankine.com/?page=orc_automobile
Even a supercharger (lobe pump):
https://en.wikipedia.org/wiki/Roots-type_supercharger
Nearly all pump & compressor types can generate shaft power when operated in 'reverse' (ie a fluid is forced through them).
There are plenty of manufacturers around but you'll need to know your working pressures, flow rates etc first. Or you could just scavenge some compressors from a junk yard and wing it.
The real question is why?
How is it that you have compressed air but need electricity?
You are much better off, in terms of cost and power generated, to generate electricity from whatever source created the compressed air in the first place, eg if your air compressor is deisel, then buy a diesel generator, you'll get maybe ten times as much electrical power per litre of diesel burnt, much cheaper in the long term, and probably cheaper capital cost too.
Likes bsheikho, russ_watters, pranj5 and 1 other person
Its better to use a wind mill to generate power.
Because you have to spend energy on compressing air anyway.
Actually, I am looking for this for a special purpose. I want to know if air is first compressed isothermally and then suddenly released adiabatically, then how much of the energy consumed during compression can be returned. Let's start with an ideal case and then go back to reality.
I also want to know what would be the temperature of air after completion of such a process.
This is a totally different question from what you asked in the OP. Please start a new thread and include the following in the opening post:
1. A complete explanation of what you are trying to accomplish including a list of all processes and their starting and ending pressures and temperatures. We don't want to have to guess what you are trying to do.
2. The results of your research into the principles and equations that govern the processes. We don't want to have to start from scratch.
Thread locked.
Likes Mech_Engineer and Nidum
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 58 ·
