Compressed Gas Expansion: Energy Transfer and Work Done
The problem involves the quasistatic expansion of one mole of nitrogen gas at constant temperature, focusing on the thermal energy transfer and work done during the process. The scenario is set in a controlled environment where the gas is compressed and then allowed to expand, with specific volume changes noted.
  • Participants discuss the relationship between thermal energy transfer (Q), work done (W), and the change in energy (ΔE), referencing relevant equations. There is an exploration of how to apply integrals in calculating work and the implications of constant temperature on energy transfer.
Some participants have provided equations and attempted to clarify the relationships between the variables involved. However, there remains uncertainty about the application of these equations, particularly regarding the integral and its cancellation. The discussion is ongoing, with various interpretations being explored.
Participants are working under the assumption of ideal gas behavior and constant temperature, while acknowledging the unrealistic nature of some conditions presented in the problem. There is mention of textbook references that may not be fully understood by all participants.
fball558
compressed temperature ?
One mole of nitrogen is compressed (by piling lots of sand on the piston) to a volume of 14 liters at room temperature (293 K). The cylinder is placed on an electric heating element whose temperature is maintained at 293.001 K. A quasistatic expansion is carried out at constant temperature by very slowly removing grains of sand from the top of the piston, with the temperature of the gas staying constant at 293 K. (You must assume that there is no energy transfer due to a temperature difference from the gas to the surrounding air, and no friction in the motion of the piston, all of which is pretty unrealistic in the real world! Nevertheless there are processes that can be approximated by a constant-temperature expansion. This problem is an idealization of a real process.) When the volume is 24 liters, how much thermal energy transfer Q has gone from the heating element into the gas?
1. When the volume is 24 liters, how much thermal energy transfer Q has gone from the heating element into the gas?
2. How much work W has been done on the piston by the gas?
3. How much has the energy of the gas changed?
i got number 3. and the answer is 0 J the other two i am completely stuck on.
um... i have no idea where to even start. might just be a simple formula but have been looking in the textbook and can not find one. any help would be great!
thanks
I used the equations on page 425 in the book to solve this.
Basically, deltaE = W + Q = 0
so you can say that W = Q
now, you just have to calculate W:
W = -integral(P dV) with your points going from V1 to V2
Substitute in for P
W = -integral( (num of moles * R * T)/V dV) from V1 to V2
so really, you do:
W = -(num moles)*R*T*ln(V1/V2) btw, R = 8.3 J/(K*mole)
ok... i saw that equation but did not know how to cancel out the integral thingy so just assumed that was the wrong equation to use.
thanks and good luck on the final (it should be a fun one lol)
how do you solve for T?
  • · Replies 67 ·
  • · Replies 33 ·
