Compute \oint F \cdot t dS of Spiral Surface
  • Thread starter Thread starter quasar_4
    Spiral Surface
quasar_4
Let S be the spiral surface parametrized by {(x,y,z) | x=ucosv, y=usinv, z=v} where 0<u<1 and 0<v<Pi/2. Let F(x,y,z) = (z,x,y) and compute \oint F \cdot t dS.
Let me explain where I'm not certain. I can compute the tangent vector t quite easily given the parametrization of S (using the chain rule) and parametrize F with x=ucosv, y=usinv, and z=v. Then I can put it all into the dot product, get a nice scalar equation, and do a surface integral over u and v - not bad. But is that the best way to approach it? Here's what I'm wondering: if I look at the spiral surface, it's not simply connected (right?) so I can't use Stoke's theorem. At least, that's what I think - but I seem to be having a hard time getting the simply connected concept into my head. Am I right (that the region isn't simply connected)? If I drew a curve around the spiral and tried to shrink it down, I'd have trouble when I got to the center of the spiral - so I think it's not simply connected...
Basically, I'm looking for the most efficient way of solving the problem. But I'm not sure if that's my approach or not. Any comments?
I am confused about your notation. The circuit integral suggests a line integral and yet you seem to be discussing a surface integral. What is the tangent vector t tangent to? And, given a circuit integral, what is the path? Given a surface, normally dS would refer to an area element. Is it to represent arc length, in which case you might mean t ds and the whole thing a line integral usually written as:
\oint \vec F \cdot d\vec{R}
And to answer your other question, that portion of the surface certainly is simply connected, in fact the whole surface is.
Oh, you're right - I don't know what I was thinking. I guess it's not even clear to me how to evaluate this as a line integral unless I can set either u or v constant. Now I am more confused.
But I guess if it's simply connected (I think I'm beginning to see how it COULD be, thank goodness) I could use Stokes' theorem and instead do the integral \int\int \nablaxFdS instead.
oops - the Tex part didn't show up. I meant that instead I could do the surface integral of curl(F) instead of the line integral F dot t.
Well, if the line integral is around the boundary of that surface, Stokes seems like a good idea. You do have a nice paramaterization to work with.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
