Convert Power Supply to 12V Lab Power Supply
In summary: I tried a computer power supply on a SSB transmitter and the rapid variation in current caused the regulator to go crazy with wide fluctuations in voltage. It didn't seem to be...
looklikeaflip
I want to convert my power supply into a "lab power supply" but a lot less simple. I just want a 12V output on it.
The power supply has 2 12V rails. Is it possible to connect both rails to increase amperage?
Thanks for you input.
One of the 12 volt rails is negative so you can't use that in parallel with the positive one and they are both grounded inside the power supply, so you can't change them.
However, the 12 volt one in my computer is rated at 10 amps, so this would be a very useful output. You can take it from one of the yellow wires that go to the hard drives. The black wires are ground.
It will probably be a bit noisy, so you might not use it for audio amplifiers and it probably wouldn't work too well if the current was changing rapidly (like in a SSB transmitter), but otherwise it should work OK.
Some power supplies won't work unless you connect the green wire on the big power plug to one of the black wires, so you might like to do that.
Sorry, I'm not a technician or anything. I'm just doing a "do-it-yourself" project. So please explain things as simple as possible.
I'm trying to power a lithium polymer battery charger to charge at its maximum current of 20 amps.
And i didnt make myself clear enough. It has two positive 12V rails. at 16Amps.
Here's the link to the Power supply.
http://redirectingat.com/?id=42X129...urnigy-charger-hobbyking-too-good-true-3.html
Again, could i group both rails together on one output to produce 32 amps?
Can the power supply handle it?
No, for the reasons that VK6KRO gave in his first sentence. ALL the different rails outputs of the PSU, the 5V, 12V, 3.3V etc all use a common negative (0V) rail
Dave
Ah, I see. PLease forgive us less educated people. The language of physics is domineering.
no probs. :) we all started somewhere
I haven't investigated the possibility of separating the various outputs to make them independant of each other. I suspect that this would be a major task. Somewhere in the circuit there will be feedback circuitry between one of the output lines and the input of the power supply, this is to stability (regulation) of the output voltages.
to VK6KRO... quite a few of us amateurs have used puter PSU's for all mode transceiver use they work very well ... just require a little more smoothing and hi freq decoupling on the output.
Dave
VK2TDN
looklikeaflip said:
Another question: If I'm only using the 12V output, can I just disregard the 5V rail and cut it off?
I'm using this as a reference on how to convert.
http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
interestings little project in that link :)
yes you could ... but I wouldnt, a +5 volt rail capable of a good number of amps is very handy. specially in a lab where you may play with a lot of digital circuits that all run on 5V
Dave
Yes, me and my cousin will have fun with this one. Very interesting.:rofl:
Is it possible to join the 5v to the 12v rail to increase amp output?
no for the same reason as above, they share the same negative line
Dave
okay, because some guy in a different forum said i can...
If your battery is actually 12 volts it may develop 14 volts when charged. This would mean that the battery would not charge from this supply. The supply always has to have a higher voltage than the battery for the battery to charge.
If the two +12 volt supplies were exactly the same voltage, you could parallel them, but this is regarded as poor practice as one could easily be slightly different in voltage to the other and this would cause the lower one to draw current from the higher voltage one.
I tried a computer power supply on a SSB transmitter and the rapid variation in current caused the regulator to go crazy with wide fluctuations in voltage. It didn't seem to be RF interference as it didn't matter if the transceiver was on dummy load or connected to an antenna.
The computer power supply was a box of whistles, too, with lots of unstable carriers in the receiver.
You can be lucky, or not, I guess.
I see. Very well said!
I have another question about Wattage use.
If a charger has a max output of 300 watts, and I know the max watts I will be charging at is 170, do I need a power supply that accommodates for the 300 or 170 watts?
I assume from the above statement you have an existing charger that uses a 12V source to charge your battery pack (ie a "car charger"), and that the maximum current draw on the 12V source is 20A? If this is the case it is quite likely your charger will operate properly from your computer power supply.
I have several PC PSUs in service for things other than PCs. They are very handy!
Fish
Output wattage is always going to be less than input wattage, typically ~ 20%. So, you 12V source would need to provide at least:
(170W/.8)/12V = 17.7A
(300W/.8)/12V = 31.5A
This is a lot of current, more than a single 12V rail in your PSU is designed to handle. You can certainly try paralleling your 12V rails. Worst case you destroy the PSU. But I would assume the PSU is designed to handle parallel connection of the 12V rails, so likely it will work. Efficiency may be pretty bad, but electricity is cheap.
Fish
You haven't said what the voltage of your battery is, required to answer this. Is it 3.7V, 7.2V...?
1. How do I convert a power supply to a 12V lab power supply?
To convert a power supply to a 12V lab power supply, you will need to follow these steps:
  1. Remove the power supply from its original casing.
  2. Identify the positive and negative terminals of the power supply.
  3. Connect a voltage regulator to the positive and negative terminals.
  4. Adjust the voltage regulator to output 12V.
  5. Connect the output of the voltage regulator to your desired load.
2. What is the purpose of converting a power supply to a 12V lab power supply?
The purpose of converting a power supply to a 12V lab power supply is to have a stable and adjustable power source for laboratory experiments and projects. This allows for precise control of the voltage and current, which is important in many scientific experiments.
3. What type of power supply can be converted to a 12V lab power supply?
Most standard power supplies with a high DC voltage output (such as 24V or 36V) can be converted to a 12V lab power supply. However, it is important to check the specifications of the power supply and make sure it can handle the desired load at 12V.
4. Can a converted 12V lab power supply be used for sensitive electronic components?
Yes, a converted 12V lab power supply can be used for sensitive electronic components as long as the voltage and current are within the safe operating range for the components. It is important to properly adjust the voltage regulator to prevent any damage to the components.
5. Are there any safety concerns when converting a power supply to a 12V lab power supply?
Yes, there are some potential safety concerns when converting a power supply to a 12V lab power supply. It is important to follow proper electrical safety precautions and make sure the voltage regulator is properly installed and adjusted. It is also recommended to use a fuse or circuit breaker as a protective measure. If you are unsure about the conversion process, it is best to consult a professional or avoid attempting the conversion altogether.
  • Electrical Engineering
