Computing the Fourier Series for f(x)=x^2
The discussion revolves around computing the Fourier series for the function f(x) = x^2 on the interval -1 < x < 1. Participants are exploring the convergence of the derived Fourier series.
  • Participants discuss the correctness of the Fourier series derived for f(x) and raise questions about the convergence of this series. There is an inquiry about the specific wording of the question regarding convergence.
Some participants confirm the correctness of the Fourier series, while others explore how to demonstrate its convergence. Various methods for showing convergence are suggested, including comparisons to known convergent series and the application of convergence tests.
There is some confusion regarding the phrasing of the convergence question, particularly the use of "if." Participants are considering the implications of theorems related to the convergence of Fourier series based on the properties of the function.
kieranl
Compute the Fourier series for the given function f on the specified interval
f(x) = x^2 on the interval − 1 < x < 1
Just wondering if anyone can verify my answer?
f(x)=1/3+[tex]\sum[/tex](4/(n^2*pi^2)*(-1)^n*cos(n*pi*x))
Yep that is correct.
cheers
the next part of the question says to determine if the function to which the Fourier series for f(x) converges?? does this make sense to anyone?
Is that exactly how the question is asked in your text? The "if" confuses me. I guess what they are asking you is if the Fourier series you just derived converges. Which is pretty easy to show.
how do you show that it converges?? just pick example numbers??
That would mean you would have to pick an infinite amount of numbers though. To show that it converges compare it to a series you know to be convergent. For example, [itex]\sum_{n=1}^\infty \frac{1}{n^2}[/itex]. You could also try the root test and or ratio test.
You should even be able to show uniform convergence if you use the right test.
there are theorems that state that when the function satisfies certain conditions, the Fourier series of the function converges to some expression. if you have learned these theorems, then it's quite easy to show that the Fourier series converges to the function itself.
  • · Replies 16 ·
