Conceptual difference between gravitational and inertial mas
Inertial mass is defined as an object's resistance to changes in velocity, while gravitational mass refers to its ability to attract other objects. Despite being conceptually different, experiments have shown that gravitational and inertial mass are numerically equal under non-relativistic conditions. The discussion highlights that at relativistic speeds, inertial mass varies, but gravitational mass remains constant, complicating the relationship between the two. The cancellation of mass in equations like F=GMm/r^2 raises questions about their conceptual differences. Ultimately, the equality of these masses is a result of experimental validation, despite their distinct definitions.
CherryWine
I know that this question has been asked many times before on this forum, but on every existing thread either the question or the answers, or both, were too vague. I understand that inertial mass is defined as the property of an object to resist change of its velocity, that is the mass that appears in Newton's Second Law F=ma. I also understand that gravitational mass on the other hand is defined as the property of an object to attract other objects. I am aware that experimentally it has been shown that gravitational mass and inertial mass are numerically the same. But, let's examine a specific problem. Let there be an object upon which acts just one single force that is gravitational. We can write F=ma. From there we can say that F=GMm/r^2, and further expand GMm/r^2=ma. Now we usually cancel m's on each sides, but how can we do this? If we know that they are conceptually different, how can we cancel them out, regardless of their identical numerical value?
I have seen that inertial mass is dependent on the velocity of the object, so when an object travels at relativistic speeds, its inertial mass is different while gravitational mass stays the same. Now, I don't know GR very well so try to answer my question having that in mind.
Thanks.
Because experiments (under non-relativistic conditions) have shown them to be equal.
Indeed. So under relativistic conditions GM/r2 = a no longer holds.
Likes CherryWine
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
