Conceptual Question About Hydrostatic Forces
The discussion centers on understanding hydrostatic pressure in a container filled with water. It emphasizes that the pressure at the bottom of the container depends solely on the height of the water column, not the diameter of the pipe above it. A smaller diameter pipe does not affect the pressure at the bottom because pressure is defined as force per unit area, which remains constant with height. The conversation also touches on the implications of adding a hollow sphere or a thin tube, questioning how these changes would influence pressure. Ultimately, the principles of hydrostatics, including Pascal's Vases, illustrate that pressure is independent of the area of the fluid's surface.
theLiminator
A 30-ft-high, 1-ft-diameter pipe is welded to the top of a cubic container (3ft x 3ft x 3ft). The
container and pipe are filled with water at 20°C. Determine the pressure forces on the bottom and sides of the container.
I already know the solution to this problem, but I don't get how it conceptually makes sense. It says that the pressure at the bottom would be equal to 33ft*specific weight of water. However, I don't get this concept. It basically means the amount of water on top makes a difference to the pressure at the bottom, only the height. My questions is, if you change the diameter of that pipe to something ridiculously small, such as 1 micron, why would the pressure at the bottom remain unchanged?
Oh, another concept I don't get:
If we attached a steel hollow sphere with a very thin thickness to the bottom, and remove to top tube, the pressure would go down right? But imagine if you add an ultra thin, but really long tube to the top, and fill that tube with water, wouldn't it crush the sphere due to incredibly high pressure? To me this isn't intuitive if you end up only adding maybe 500g of water (when using an incredibly thin tube).
Aren't the units of pressure (force by area) like psi. So you'll have the same pressure with the same height of water because pressure is independent of the actual area.
You're just saying that this much force is acting per this area (which is a constant).
This makes sense to me, I hope its right and hope it helped.
As far as I know it should be. Try to google and find something about Pascal's Vases or hydrostatic paradox.
Thread 'How do I determine the resistance for RLC low pass filter?'
Hi, I am trying to build a RLC low pass filter that atenuates the frequency below 4500 Hz. However, I have encountered some problem when choosing the correct R to work with. Here is the Circuit Here is the original sound. Here is my code in Matlab function Vout = myFilterCircuit(Vin,h) n_V = length(Vin); f_7 = 4470;; % Undesired frequency h_7 = h; % delta time % These are for the constant and initialization of the variables t_7 = 0:h_7:(n_V-1)*h_7; % This is the independent variable...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
