Conceptual questions on unitarity and time evolution
"Don't panic!"
From a physical perspective, is the reason why one requires that the norm of a state vector (of an isolated quantum system) is conserved under time evolution to do with the fact that the state vector contains all information about the state of the system at each given time (i.e. the probabilities of it having a particular energy, momentum, etc..) and so when it is evolved in time, although the individual probabilities of each observable will change, the total probability will always be conserved, since there is no external influence on the system and so the set of allowed values for each observable will not increase/decrease. That is, the observables of the evolved quantum system must assume values (with a certain probability) from the original set of values (that they could "choose from" at the initial time) ?! (sorry, I feel I haven't worded this part in the most articulate way).
Additionally, does the composition of two evolution operators, i.e. $$U(t_{2},t_{0})=U(t_{2},t_{1})U(t_{1},t_{0})$$ follow from the requirement that quantum evolution is Markovian, that is, that one can obtain the same results by knowing the state of a system at a given instant in time as one would obtain from knowing complete evolution of a system? For example, Say one observer knew the state of a quantum system at an initial time ##t_{0}## to be ##\lvert\psi (t_{0})\rangle##. The system is then allow to evolve to its state at some later time ##t_{2}##, ##\lvert\psi (t_{2})\rangle=U(t_{2},t_{0})\lvert\psi (t_{0})\rangle##. Another observer doesn't know what state the system was in at time ##t_{0}##, but does know the state of the system at some time, ##t_{1}##, ##\lvert\psi (t_{1})\rangle## (with ##t_{0}<t_{1}<t_{2}##). Again, the system evolves from its state at time ##t_{1}##, ##\lvert\psi (t_{1})\rangle##, to its evolved state at time ##t_{2}##, described by this observer by ##\lvert\psi (t_{2})\rangle=U(t_{2},t_{1})\lvert\psi (t_{1})\rangle##. Since the final state is the same for both observers, and the first observer will also be able to determine the evolved state at ##t_{1}##, ##\lvert\psi (t_{1})\rangle=U(t_{1},t_{0})\lvert\psi (t_{0})\rangle## (since they know the state of the system at the earlier time ##t_{0}##), it follows that $$\lvert\psi (t_{2})\rangle=U(t_{2},t_{1})\lvert\psi (t_{1})\rangle=U(t_{2},t_{1})U(t_{1},t_{0})\lvert\psi (t_{0})\rangle=U(t_{2},t_{0})\lvert\psi (t_{0})\rangle\\ \Rightarrow\quad U(t_{2},t_{1})U(t_{1},t_{0})=U(t_{2},t_{0})$$
Would this be a correct description at all?
Wigners Theorem
Thanks
Bill
bhobba said:
Wigners Theorem
So is the idea that the outcome of an experiment should be independent of the time that it was carried out? In my example, is the point that if one experimenter starts the experiment with a system (call it A) in some particular state at some earlier time and then another experimenter starts an experiment at a later time in which the system they are considering (call it B) is in an identical state to the state that the system A has evolved to at this later time, then from this point both should evolve (assuming the experimental conditions are identical) such that their final states, at some much later time, are identical?
What you wrote is rather convoluted.
Its much easier to view as simply a change in coordinates which fairly obviously shouldn't change the physics, in particular it shouldn't change the probabilities from the Born rule. It would be very very weird if simply changing the where the origin of your coordinate system is or the velocity its moving changed that..
While its rather obvious in actuality you are invoking the POR - Principle Of Relativity:
https://en.wikipedia.org/wiki/Principle_of_relativity
Thanks
Bill
Sorry I realize it is quite convoluted, but I was really trying to put in words what is conceptually going on, and why ##U(t_{2},t_{0})=U(t_{2},t_{1})U(t_{1},t_{0})##, in terms of relating a quantum state at some initial time to it's evolved states at later times.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
