Conceptual work/energy question
  • Thread starter Thread starter Inertialforce
    Conceptual
The discussion focuses on a physics problem involving two slides of the same height but different angles. It concludes that the horizontal distance from the edge of the slide remains unchanged when neglecting friction and air resistance. The reasoning is based on the conservation of energy principle, where the change in potential energy equals the change in kinetic energy. Since the height remains constant, the angle of the slide does not affect the overall energy conversion. Thus, the steeper slide does not alter the horizontal distance traveled.
Inertialforce
Person A is seen going down a slide with height "h". A few seconds later the same person A is seen going down a steeper slide with the same height "h" (same height for both slides). Using principles of physics, explain how the new horizontal distance from the edge of the slide compares with the first situation. Friction and air resistance are negligible.
The conclusion I came to was:
With the new horizontal distance from the edge of the slide, nothing would change because if you neglect the effects of friction and air resistance then that means that you neglect all non-conservative forces and the work done by it. Therefore without any non-conservative forces to effect the system, the change in potential energy would therefore equal the change in kinetic energy (or ΔEp = ΔEk). To sum it up, the steeper slide makes no difference because the only thing that has changed is the angle of the slide.
Would this be correct?
Likes Neha Siddhartha
Correct.
Remember since h remains the same. Ep and Ek are related by v = \sqrt{2gh}
