What are the conditions for using the Laplace transform?
Jhenrique
The Laplace of 1 is:
$$\int_{0}^{\infty} 1 \exp(-st) dt = \left[ \frac{\exp(-st)}{-s} \right]_{0}^{\infty} = \frac{\exp(-s \infty) - \exp(-s 0)}{-s} = \frac{0 - 1}{-s} = \frac{1}{s}$$
It's result known, however, for this be true is assumed that s>0, because 0 = exp(-∞) = exp(-s∞). But we have a problem, s is a complex number (σ + iω), so you assume that s>0 thus you are saying that ω=0, but in laplace transform ω≠0. The most correct possible would be ##\exp(-s∞) = \exp(-(σ + iω)∞) = \exp(-σ∞ - iω∞) = \exp(-\text{sgn}(σ)∞ - i \text{sgn}(ω)∞) = \frac{\exp(-\text{sgn}(σ)∞)}{\exp(i \text{sgn}(ω)∞)}##, but it's become inpraticable... So what is correct form of approach this calculation of a simple way?
No, the assumption is that Re(s) > 0. See http://en.wikipedia.org/wiki/Laplace_transform, Table of selected Laplace transforms. Note the column whose heading is "Region of convergence."
Likes 1 person
Humm, but s is a complex number, so what is the conditition for Im(s)?
As far as I know, there aren't any conditions on Im(s).
Likes 1 person
What you wrote above is pretty much meaningless. You cannot use ∞ in arithmetic expressions.
Why not?
Jhenrique said:
Why not?
Maybe they're not needed. I dug up my book on Advanced Engineering Mathematics, Third Edition (Erwin Kreyszig) and looked at the section where he talks about Laplace tranforms. He doesn't even mention that s is complex. To see a treatment on the Laplace transform that deals with complex values of s, I looked at my copy of Churchill's Complex Analysis, which doesn't have any topics on this tranform, and then my Jerrold Marsden "Basic Complex Analysis," which does include this topic.
The Laplace transform is usually defined as this integral (which I believe you know):
$$F(s) = \int_0^{\infty}e^{-st}f(t)dt$$
The defining theorem for this transform says that there is some real number σ for which the above integral converges if Re(s) > σ, and diverges if Re(s) < σ.
If you want to know more than that, you'll need to study complex analysis.
Likes 1 person
