Low-Q
- 9
I have a discussion going on with some friends. The discussion goes like this:
We have two identical tanks. One is empty. One is full of water. Both placed on the ground.
They are connected with a hose at the bottom. There is a ball valve in line with the hose.
The full tank has a given potential energy in it. The second one has zero potential energy in it because it is empty.
Now, If we open the valve, water starts to flow from one tank to the other. The potential energy increase in the empty tank, and decrease in the full tank. Finally they will level out to same amount of water. Half full each.
The flow through the hose activates a flawless turbine (for the simplicity). The turbine provides electricity to a load that heats up.
We also have an outlet hose from each tank, connected together. There is a turbine in those hoses too.
Now we open thiese outlets and let water flow from both tanks through the turbines.
The claim made from my friends is that it is possible to get 150% energy out of the tank(s). 50% potential energy from the full tank flowing into the emty one, and 100% from both tanks when opening the second valve.
Initially we discussed electric capacitors. 10uF each. One charged with 10V. Then these are connected via the load. The claim is that both capacitors finally will have 5V each. Then we empty the capacitors together with a load and they claim to achieve more energy out during discharge than we put in during charging the one capacitor.
I do not agree, but lacks a good phrase that I can use as explanation.
Hope you can help :-)
Vidar
Vidar
