Confusion with the centrifugal foce and potential energy
The discussion centers on the recovery of centrifugal potential energy in rotating frames of reference, specifically in scenarios involving suspended objects and rotating systems. Participants clarify that centrifugal potential energy is only relevant in a rotating frame, where releasing an object converts this potential energy into kinetic energy. An example involving a mass on a string in a rotating space station illustrates how approximately 10 Joules of energy can be harvested during the object's descent, highlighting the interplay between centrifugal potential energy and kinetic energy. The conversation emphasizes the need to reconcile perspectives between rotating and inertial frames to fully understand energy transformations.
  • Understanding of centrifugal force in rotating frames
  • Basic principles of potential and kinetic energy
  • Familiarity with energy conservation laws
  • Knowledge of inertial versus non-inertial reference frames
  • Research the mathematical integration of centrifugal force to derive potential energy
  • Explore energy harvesting techniques in rotating systems
  • Study the differences between inertial and non-inertial frames of reference
  • Investigate practical applications of centrifugal potential energy in engineering
Physicists, engineers, and students interested in mechanics, particularly those exploring energy transformations in rotating systems and the implications of centrifugal forces.
tolove
When we release a suspended object, we recover the potential energy due to gravity as the object travels back through the height raised.
When we release an extended spring, we recover the potential energy as the object travels back through the distance stretched.
But when we release a rotating object, how is the centrifugal potential energy recovered?
I know that if we integrate the centrifugal force over the radius, we can numerically recover the potential, but I still feel as if I am missing something.
Thank you for your time!
Centrifugal force and centrifugal potential energy exist only in a rotating frame of reference. If you release on object that was initially at rest in the rotating frame, it will gain speed in the rotating frame, converting centrifugal potential energy into kinetic energy.
In the inertial frame it's of course just moving at constant speed, not gaining any kinetic energy.
Hi.
I imagined your case hammer throw with chain replaced by spring.  Spring is extended by rotation of the player. When he releases the hammer, weight and spring make vibration.  Spring gets elastic energy by downing weight in centrifugal potential. Spring elastic energy convert to vibration energy by the release.
The scenario I imagine is different. Possibly we need to ask OP to clarify things.
Suppose that you are standing on the floor of a rotating space station. You have a mass on a string and allow it to drop from table to floor while harvesting the energy as the string pays out. For a 1 kg object dropping 1 meter under 1 g of artificial gravity you could harvest ~10 Joules of centrifugal potential energy in this manner. You could use this to partially recharge a battery.
But if one adopts a non-rotating frame of reference and looks at the same scenario, there is a conundrum. There is no centrifugal potential to harvest. 10 Joules of energy went into charging a battery. The object moved 1 meter farther from the center of rotation and ended with more kinetic energy than it started. Where did the energy come from?
It came from the rotation of the space station. We can walk through the details that reconcile the two points of view if OP is interested.
  • · Replies 31 ·
11K
  • · Replies 16 ·
11K
