Undergrad Can We Choose a Coordinate System for a Levi-Civita Connection on Manifolds?
The discussion centers on the relationship between coordinate systems and the Levi-Civita connection on manifolds. It is established that the Levi-Civita connection is unique in being both torsion-free and metric-compatible, and its properties do not depend on the choice of coordinate system. The connection coefficients, however, are dependent on the coordinate system and transform accordingly. The conversation also touches on the implications of torsion in relation to the connection and the nature of tangent spaces.
  • Understanding of differential geometry concepts, particularly affine connections.
  • Familiarity with the Levi-Civita connection and its properties.
  • Knowledge of tensor calculus and the transformation of connection coefficients.
  • Basic understanding of manifolds and tangent spaces.
  • Study the properties of the Levi-Civita connection in detail.
  • Learn about torsion in differential geometry and its implications.
  • Explore the transformation rules for connection coefficients under coordinate changes.
  • Investigate the role of tangent bundles in the context of connections on manifolds.
This discussion is beneficial for mathematicians, theoretical physicists, and students of differential geometry who are exploring the intricacies of connections on manifolds and their geometric implications.
kent davidge
I was thinking about connection coefficients. Can we choose a coordinate system so that we have a Levi-Civita connection? Or is it a thing imposed on us by the manifold?
EDIT: I realize that, from a geometric perspective, since we'd be dealing with a manifold we would have no torsion around any point as long as the region is small. So my question is more like can we choose a coordinate system so that it vanishes everywhere?
The connection coefficients belong to the connection you impose on your manifold and the Levi-Civita is a particular connection that can be applied (i.e., the unique metric compatible and torsion free connection). If your connection is not the Levi-Civita connection, you will not have the Levi-Civita connection's connection coefficients.
If you do not have a torsion free connection you cannot make torsion vanish. Torsion is a type (1,2) tensor and its vanishing or not does not depend on the coordinate system, only on the imposed connection. "Vanishing locally" is not a thing that non-zero torsion would do. It is a tensor and only depends on the point of interest, not on a region around a point.
Does Relativity theory allow for manifolds with torsion?
I'm not sure I understand the question. Suppose we have a flat Euclidean plane. One can choose any of an infinite number of coordinate systems (for instance Cartesian and polar, to name two of the infinite set) with the Levi-Civita connection.
The way your question is worded, it sounds like you are regarding the connection as a consequence of the coordinate system, whereas I think of the connection as a tool that allows one to define a derivative operator in a manner that's independent of one's particular choice of coordinates, which are therefore free to be chosen at one's convenience.
See for instance wiki:
In the branch of mathematics called differential geometry, an affine connection is a geometric object on a smooth manifold which connects nearby tangent spaces, and so permits tangent vector fields to be differentiated ...
Likes kent davidge
Oh, I see
I'm actually thinking of the ##\Gamma## as ##\Gamma^\kappa{}_{\mu \nu} = \partial_\mu e_\nu (x)##. Is it ok?
kent davidge said:
Oh, I see
No. First of all, the partial derivative of a vector is meaningless (unless you have a unique way of relating vectors in different tangent spaces, such as in Euclidean space, but in a general manifold you don’t). Resolving this is the entire point of introducing a connection.
Second, your indices don’t match, you are missing a basis vector. By definition of the connection coefficients are
\nabla_\mu e_\nu = \Gamma_{\mu\nu}^\rho e_\rho.
Note that what appears here is the connection, not the partial derivative.
They are functions of ##x##. So I thought that's fine. I would like to know why we can't study their variation with ##x##, i.e. their derivatives wrt ##x##.
Because in order to create the difference you should take the limit of you would need to take the difference of vectors in different tangent spaces. As you were told in an earlier thread the tangent spaces of different points are different vector spaces. This is what the connection is for. It essentially tells you how nearby tangent spaces fit together.
Ok I understand that. What I think is confusing me is that the basis vectors are typically written like ##e(x)##, that seems to imply they are functions of ##x##. So is it more correct to write just ##e##?
Yes. This happes for e.g. fermionic fields. In supergravity one usually has torsion due to the gravitino field(s).
Likes kent davidge
Why would that be more correct? Basis vectors can, as you say, be functions of the coordinates you use to cover your manifold.
Likes kent davidge
The basis is a function of the coordinates (or more correctly, of the point in the manifold), but a vector field (or in more mathematical language, a section of the tangent bundle) assigns to each point ##p## in the manifold an element of ##T_p M##, i.e., a vector in the tangent space of ##p## itself.
The more formal way of writing this would be that if you have a manifold ##M##, then a vector field is a map ##\sigma: M \to TM##, where ##TM## is the tangent bundle of ##M## (i.e., the union of all tangent spaces), such that ##\pi(\sigma(p)) = p## if ##\pi## is the projection function ##\pi: TM \to M## with the property that ##\pi(X) = p## if ##X \in T_pM##.
Likes vanhees71 and kent davidge
It is an interesting question, I think the answer to this question is 'yes', the reason is: if we start from a flat metric ##\eta_{ij}=I##, and the corresponding Levi-Civita connection ##\Gamma=0##. Then under a coordinate transformation ##x\rightarrow x'##, the flat metric ##\eta_{ij}## is a tensor field, so it changes to a new metric ##g_{ij}(x)##, and the connection ##\Gamma## corresponding to ##\eta_{ij}## also changes to a new connection ##\Gamma'##, and we can get:
$$\partial e'(x)=\Gamma'(x) e'(x)$$
The key problem of this question is that what kind of ##\Gamma'## can we get through coordinate transformation, can we get
an arbitrary connection field ?
Likes kent davidge
No. The correct answer is that the connection has nothing to do with the coordinate system. If your connection is the Levi-Civita connection it will be the Levi-Civita connection in all coordinates. If it is not it will not be the Levi-Civita connection in any coordinates.
After learning about the concept of bundle, it became more clear to me that coordinates don't play a role in this case.
Jianbing_Shao said:
The key problem of this question is that what kind of ##\Gamma'## can we get through coordinate transformation, can we get an arbitrary connection field ?
As of my current understanding, locally the manifold is to be thought of as a product space, one is called the base space and the other is the fiber.
The connection appears as an element of the structure group, which maps basis vectors into basis vectors. AFAIK they are elements of ##GL_n(\mathbb R)##. Now the coordinates have to do with the parametrization one implements on the manifold. It gives a way for one to know how two connections when expressed in coordinates, are related. I would like someone to correct me if I'm wrong.
Ok, if you think ''the connection has nothing to do with the coordinate system.'' then how can you explain the change rule of the connection field under the coordinate transformation?
For example if we can change a connection field to another arbitrary connection field through coordinate transformation, then what relationship between the connection and the coordinate transformation? Do you still think ''connection has nothing to do with the coordinate system.''?
Another question, what is the relation between Levi-Civita connection and connection? how can you find out if a connection is a Levi-Civita connection or a non-Levi-Civita connection?
I said the connection has nothing to do with the coordinates (and it doesn’t), not that the transformation of the connection coefficients do not follow the appropriate transformation rules. Since connection coefficients depend on the coordinates, obviously the transformation rules do. However this tells you nothing about the connection as such. Do not confuse the connection with the connection coefficient transformations.
You can have different connections using the same coordinates and you can have the same connection expressed in different coordinates. The transformation rules describe how the latter works but has nothing to do with the former.
Again, you do not change the connection by changing coordinates. You are just changing the coordinate system it is expressed in.
It is a fact that the connection is independent of the coordinates, it is not a matter of thinking, it is a property of the connection on the fibre bundle in question.
The Levi-Civita connection is the unique torsion-free and metric compatible connection, ie, no other connection satisfies these requirements.
Likes Pencilvester
''connection has nothing to do with the coordinates'' but the connection coefficients do, connection coefficients changes under the coordinate transformation and connection do not,
So I can draw a conclusion if connection has nothing to do with the coordinates ,obviously it also has nothing to do with the connection coefficients,
If you have a point with coordinates ##x^{\mu}## and another with coordinates ##x^{\mu}+\delta x^\mu##, then the connection tells you which vector in the tangent space of ##x^\mu+\delta x^\mu## is defined to point in the same direction as a vector in the tangent space of ##x^\mu##. Of course, if we change coordinates then the numbers we use identify the two points change, from ##x^\mu## to ##x^{\mu'}##. But they're still the same points. The numbers we use to describe the vectors change too. But the vectors are still the same. So the numbers we use to describe the connection must change. But the connection is still the same. How could it be otherwise? The concept of "pointing in the same direction" is the same whatever coordinates we use - at least in physics where we take out cues from how stuff works in the real world.
At least, that's my understanding.
Your choice of connection does not depend on coordinates. You choose a connection and a set of coordinates independently, and your connection coefficients are determined by those two choices.
No. I don’t know where you got that idea from as it does not logically follow. That is like saying that the components of a vector have nothing to do with the vector itself. The vector itself is independent of whatever basis you choose, but the vector components depend both on the vector and on the basis. Same thing for the connection coefficients, they depend on the connection and on your choice of coordinates.
Maybe too much, but another 2 cents: look at post #6, where the connection coefficients are defined. This definition is coordinate independent. That already should answer your question. Of course, after that you can derive the transformation law under a coordinate transformation when you change coordinate charts.
Look at it this way: a car is defined by certain properties. Let's take these properties to be the number of wheels (4), engine power, and weight. After that you can describe such a car in different colour patterns, like black, blue or red. But the colour just changes the description of a specific type of car. The colour cannot change this type. Here, the analogy is car <--> connection and colour <--> coordinates.
I think that maybe it's clearer that the connection is coordinate-independent if you think in terms of parallel transport. You have a starting point, ##A##. You have a starting vector, ##V_A##. You take the vector on a journey along a path ##\mathcal{P}(s)## to get to a point ##B##. All along the way, you try to keep the vector pointing in the "same direction" and having the "same magnitude". You end up with a vector at point ##B##: ##V_B##. The connection is what tells you that ##V_A## and ##V_B## are the "same" vector (or as close to being the same as you can get in following the path ##\mathcal{P}(s)##.
There is nothing in this description that in any way depends on coordinates. You have defined a vector at ##B## as a function of a vector at ##A## and the path to get from ##A## to ##B##.
Following this discussion with some interest and I wanted to make sure I was thinking about this correctly. If you choose a set of coordinates and a connection, then choosing a tangent space basis at one point on the manifold determines it everywhere else, right?
Follow up: if the above is true, does choosing a set of coordinates along with a basis at every point on the manifold determine the connection?
No, this is not correct. The parallel transport of the basis from the point you chose it at to another point will generally depend on the path unless your manifold is flat and simply connected.
Likes TeethWhitener
Yes, thank you. I realize now that it doesn’t make sense. But if you define your coordinates and define a tangent space basis at every point, does that determine a connection, since the connection tells you how the basis changes from point to point?
That's not quite right. Think about the surface of the Earth. On every point except the North and South pole, you can define a basis by the following:
  • Let ##e_y## be a unit vector pointing North.
  • Let ##e_x## be a unit vector tangent to the surface of the Earth which is perpendicular to ##e_y## (so that ##e_x## is 90 degrees clockwise away from ##e_y##, looking down on the Earth)
This gives you a basis for each point on the Earth (well, except two---nobody lives there, anyway). But it doesn't define the connection. What you need to define the connection is a way to relate the tangent spaces of nearby points. If you have two points ##A## and ##B## that are close by, you need a way to rewrite a vector ##V## defined at point ##A## to a corresponding vector ##V'## defined at point ##B##.
I think your idea for defining the connection by just giving a basis at each point might have been to say: Define ##V'## at ##B## by:
  • ##V'^x = V^x##
  • ##V'^y = V^y##
That's simple enough, but it can't possibly work on a curved surface.
This is not entirely true. You can use these two vector fields to define a connection (in fact, it is one of my favourite examples of a metric compatible connection with non-zero torsion and Example 9.15 and some follow-up examples in my book discuss it and its geodesics). What it does not do is to let you define the Levi-Civita connection (which, apart from being metric compatible, is torsion free). If you have set of fields that are linearly independent at each point, you can define a connection by defining them to be parallel. This is the reason that you need to remove points from the sphere - it is not parallelisable.
This is a bit of chicken-or-egg. It is the connection that determines whether the surface (or, more generally, manifold) is curved or not. Of course, the connection discussed above has zero curvature. A vector parallel transported around a loop always has the same length and bearing, since the connection is metric compatible. (And it is metric compatible because the basis defined is orthonormal everywhere ...)
You do not need the coordinate system, but if you have a set of basis vector fields, then you can define a connection by defining how the connection acts on those fields. In particular, you could define those fields to be parallel. However, there is no guarantee that this connection will have particular properties, such as being the Levi-Civita connection.
What's the connection? Do you just assume that parallel transport of a vector ##V## leaves the components ##V^x## and ##V^y## unchanged?
  • · Replies 26 ·
  • · Replies 40 ·
  • · Replies 18 ·
  • · Replies 51 ·
