Conservation Laws and Symmetries Particle Physics
3 replies · 3K views
highwayman1739
2) A π0 of kinetic energy 350 MeV decays in flight into 2 γ rays of equal energies. Determine the angles of the γ rays from the incident π0 direction.
Not sure where I am going wrong but my answer is not correct.
Energy of π0 meson
E = 350 MeV
Rest mass Energy of π0 meson
E0 = 135 MeV
Initial momentum of π0 meson
P = √E^2 – Eo^2 / c
P = √(350 MeV)^2 – (135 MeV)^2 / c
P = 322.9163978 MeV/c
Law of conservation of Energy
E = Egamma + Egamma
Egamma = E/2
Egamma = 350MeV/2
Egamma = 175 MeV
Angle of gamma ray
θ = cos-1(Pc / 2E)
θ = cos-1(322.9163978 MeV/c) c / (2)(175 MeV)
θ = cos-1(0.922618279)
θ = 22.688 degrees
Energy of π0 meson
E = 350 MeV
E0 = 135 MeV
According to the problem statement, the kinetic energy is 350 MeV. The total energy, E, is the kinetic energy plus the rest mass energy.
P = √E^2 – Eo^2 / c
It wouldn't hurt to use parentheses or brackets in your notation.
p = √(E^2 – Eo^2)/ c
or
p = √(E2 – Eo2)/ c
or
[itex]p = \frac{\sqrt{E^2 - E_0^2}}{c}[/itex]
Here you need to add the rest mass energy to the kinetic energy to find the total energy, E. :wink:
If I add kinetic energy and rest energy (350+135 = 485 MeV) and use this value for E my momentum seems to be to large (p = 465.83). Unless I am making another mistake in the part below.
θ = cos-1(Pc / 2E)
θ = cos-1(465.83 MeV/c) c / (2)(175 MeV)
θ = cos-1(1.33)(which cannot be )
So far that looks right to me. :approve: Specifically, I got 465.83 MeV/c.
θ = cos-1(Pc / 2E)
That's almost right, but you're missing an additional factor of 2 in there somewhere. I see you've put one '2' in there already, presumably because each photon's contributes half of the total momentum in the x direction. But also remember that each photon contributes half the total energy too. I only see one of the factor of '2's in there.
There is another way to do this, which is the long way. Use the formula E = hc/λ, and solve the the wavelength of each photon (remember that each photon only contributes half the total energy. Then realize |p| = h/λ, and that the x-component of each photon's momentum, px = pcosθ = hcosθ/λ, contributes to half the total momentum of the original pion. (Don't worry about the momentums in the y-direction, they are equal and opposite, so they cancel.)
You'll end up with a cosθ = ratio, where the "ratio" is guaranteed to be be less than 1 (assuming the original pion had non-zero rest mass, which of course is true).
[Edit: corrected a mistake.]
