Conservation Laws and Symmetries Particle Physics
The discussion revolves around a problem in particle physics concerning the decay of a π0 meson with a kinetic energy of 350 MeV into two γ rays of equal energies. Participants are tasked with determining the angles of the γ rays relative to the direction of the incident π0 meson.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to calculate the initial momentum of the π0 meson using its total energy, which includes both kinetic and rest mass energy. There is discussion about the correct formulation of momentum and energy conservation principles.
Some participants are questioning the calculations of momentum and energy, particularly regarding the addition of kinetic and rest mass energy. Others are exploring different approaches to the problem, including the use of photon momentum and energy relationships. There is no explicit consensus on the correct method or values yet.
Participants note potential issues with notation and the need for clarity in mathematical expressions. There is also mention of the implications of the rest mass of the π0 meson on the calculations, and the importance of correctly accounting for energy contributions from both γ rays.
highwayman1739
2) A π0 of kinetic energy 350 MeV decays in flight into 2 γ rays of equal energies. Determine the angles of the γ rays from the incident π0 direction.
Not sure where I am going wrong but my answer is not correct.
Energy of π0 meson
E = 350 MeV
Rest mass Energy of π0 meson
E0 = 135 MeV
Initial momentum of π0 meson
P = √E^2 – Eo^2 / c
P = √(350 MeV)^2 – (135 MeV)^2 / c
P = 322.9163978 MeV/c
Law of conservation of Energy
E = Egamma + Egamma
Egamma = E/2
Egamma = 350MeV/2
Egamma = 175 MeV
Angle of gamma ray
θ = cos-1(Pc / 2E)
θ = cos-1(322.9163978 MeV/c) c / (2)(175 MeV)
θ = cos-1(0.922618279)
θ = 22.688 degrees
Energy of π0 meson
E = 350 MeV
E0 = 135 MeV
According to the problem statement, the kinetic energy is 350 MeV. The total energy, E, is the kinetic energy plus the rest mass energy.
P = √E^2 – Eo^2 / c
It wouldn't hurt to use parentheses or brackets in your notation.
p = √(E^2 – Eo^2)/ c
or
p = √(E2 – Eo2)/ c
or
[itex]p = \frac{\sqrt{E^2 - E_0^2}}{c}[/itex]
Here you need to add the rest mass energy to the kinetic energy to find the total energy, E. :wink:
If I add kinetic energy and rest energy (350+135 = 485 MeV) and use this value for E my momentum seems to be to large (p = 465.83). Unless I am making another mistake in the part below.
θ = cos-1(Pc / 2E)
θ = cos-1(465.83 MeV/c) c / (2)(175 MeV)
θ = cos-1(1.33)(which cannot be )
So far that looks right to me. :approve: Specifically, I got 465.83 MeV/c.
θ = cos-1(Pc / 2E)
That's almost right, but you're missing an additional factor of 2 in there somewhere. I see you've put one '2' in there already, presumably because each photon's contributes half of the total momentum in the x direction. But also remember that each photon contributes half the total energy too. I only see one of the factor of '2's in there.
There is another way to do this, which is the long way. Use the formula E = hc/λ, and solve the the wavelength of each photon (remember that each photon only contributes half the total energy. Then realize |p| = h/λ, and that the x-component of each photon's momentum, px = pcosθ = hcosθ/λ, contributes to half the total momentum of the original pion. (Don't worry about the momentums in the y-direction, they are equal and opposite, so they cancel.)
You'll end up with a cosθ = ratio, where the "ratio" is guaranteed to be be less than 1 (assuming the original pion had non-zero rest mass, which of course is true).
[Edit: corrected a mistake.]
  • · Replies 54 ·
12K
  • · Replies 34 ·
