Conservation of Energy & circular motion
The discussion revolves around solving a classical physics problem related to conservation of energy and circular motion. The user seeks guidance on their proof attempt, specifically addressing the total energy in the system, which is expressed as m*g*L. They derive equations for velocity at the top of a circular path and relate kinetic and potential energy. The final substitution shows the relationship between energies, confirming the conservation principle. The user expresses gratitude for the assistance received in clarifying their approach.
nrahim
The problem is stated on the sheet i have attached along with my attempt to the possible solution. This is a proof and i am very bad at working with proofs. This seems to be a classical problem so I'm sure some of you guys might have seen it, please guide me!
http://img22.imageshack.us/img22/1405/53811275.th.jpg
I have posted the problem with what i have tried... as you can see i was stuck, please guide me if my logic or math is wrong
Welcome to PF.
Consider the conditions imposed.
Total energy in the system is m*g*L
To complete a circle then with Vt the velocity at the top of the circle about x
m*Vt2/(L-x) = m*g
m*Vt2 = m*g*(L-x)
So ... at the top of that loop
1/2*m*Vt2 + m*g*(2*(L-x)) = m*g*L
Substituting ...
1/2*m*g*(L-x) + m*g*(2*(L-x)) = m*g*L
thanks a lot my friend.. you saved me a lot of hassle:D
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
