Conservation of Energy, thinking question
When a compressed spring in a vacuum is released, the stored potential energy, calculated as 1/2kx^2, converts into kinetic energy, represented by 0.5mv^2. In the absence of friction, the velocity of the spring's mass remains constant initially, allowing for efficient energy transfer. However, if the spring oscillates, internal resistances will eventually dampen the vibrations, leading to energy conversion into heat. This process illustrates the conservation of energy, as energy shifts forms rather than disappearing. Ultimately, the energy transitions from potential to kinetic and then to thermal energy due to damping effects.
ninevolt
Since we all know that energy is conserved, it is converted from one form to another, I want to ask you what happens to the energy when a compressed spring, in a vacuum is released? Where does the energy go, does it simply become heat energy in the spring, or is it transferred another way?
I thinks the energy in the spring which equals 1/2kx^2 will transfer into a K.E which equals to 0.5mv^2, and the v will not decrease because we have no friction there.
If it is released and oscillates, internal resistances will dampen the vibration and convert the energy to heat.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
