Conservation of linear momentum problem
A particle of mass 5m moving at speed v explodes into two pieces with masses 2m and 3m, where the lighter piece moves at a speed of 5v relative to the heavier piece. The conservation of linear momentum must be applied, leading to the equation 5m(v) = 2m(Vsmall) + 3m(Vlarge). The confusion arises from the term "relative," which indicates that the speed of the lighter piece is 5v faster than the heavier piece, expressed as Vsmall = Vlarge + 5v. Correctly setting up the equations and understanding the relative velocity is crucial to solving the problem. Clarifying these concepts will help in finding the actual speed of the lighter piece.
risingabove
A particle of mass 5m moving with speed v explodes and spilts into two pieces with masses of 2m and 3m. The lighter piece continues to move in the original direction with speed 5v relative to the heavier piece. what is the actual speed of the lighter piece?
using law of conservation of linear momentum
initial moment = final moment
mass (m) x Velocity (v) = mass (m) x Velocity (v)
using the formula...
5m (v) = 2m(v) - 3m (5v) ...) i used the minus (-) sign because the heavier piece went a different direction
5mv = 2mv -15mv
20mv = 2mv
10v = v
but my answer was wrong...
PLEASE HELP EXPLAIN WHY AND WHAT IS IT IM MISSING TO DO>>>
FIRST CLASS TEST IS TOMORROW!
That's not correct. You appear to be assuming that after the explosion the large bit is moving five times faster than the small bit. That's not what the problem states.
I wouldn't recommend that. I would just define
Vi is the initial velocity
Vsmall as the new velocity of the small bit
Vlarge as the new velocity of the large bit
So with that in mind it should be something like
5mVi = 2mVsmall + 3mVlarge
I'll let you figure out the other equation to write.
Sorry for the edits to my reply.
ok soo would i know say
5mVi - 3mVlarge = 2mVsmall
Ok i think I am confusing myself but i do get and understand what you were saying...i think the "relative" word in the problem is what confusing me...
what do they mean when they say "...with a speed 5v relative..."
Pleas Helppp...i really want to understand this
Im still stuck on this question can someone give any insights..? PLEASE...
Yes
it's how much faster it's moving. Vsmall = Vlarge + 5v.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
